Results 1 to 10 of 1184
June 10th, 2011 04:03 PM #1
[quote] Originally Posted by dvldoc
A good add on to this thread if people can post the aftermarket filters they see on the shelf there so we can tell you which are the good and the not so good.
So far we know this.
Fleetguard - Fleet service heavy duty filter
Baldwin- Fleet service heavy duty filter
Bosch- good over the counter filter
Mann- decent filter not the best specs for efficiency but well built
Fram- Orange can of death, one of the worst on the market.
OEM-Toyota black can not made by Mann, Low quality filter
OEM-Honda low quality filter paper end caps, cheaply made
OEM-Madaz decent filter good for 5000k oil changes
OEM-Nissan white can, total garbage, foam filter media thin cardboard
Nissan- made by Mann, decent over the counter filter 5000k use.
Mobil1-good over the counter filter
K&N - good over the counter filter
WIX- above average oil filter heavy duty construction.
OEM-Ford (Motorcraft filter) Good over the counter filter
ACDelco-None Ultraguard and Duraguard are of very low quality
OEM-Hyundai-good OEM filter
VIC- Very cheaply made, restrictive bypass valve, poor filter media
Union-Decent over the counter filter, basic paper media 5000k Change out
JHF- Decent Koren made over the counter filter 5000k use
Fil- lable says (for) Toyota, red and white box, Yellow lettering on filer, undersized filter media, bad bypass valve cause filter to recirculate unfilterd oil.
Fil-Fram Koren version. same issues. Steel on steel relief valve fails to seal, leaves dirty oil circulating.
Toyota (Denso) Japan, has on average fewer pleats for fitering vs other filters. Example MANN has 60 pleats vs Densos 29, vs Frams 59 in the same size filter. Very short life filter.
Fellow Tsikot member await your input[quote/]
Purolator makes good oil filters as well!
Read more: http://tsikot.com/forums/engine-fuel...#ixzz1Or1EcsGlFasten your seatbelt! Or else...Driven To Thrill!
April 3rd, 2012 07:18 PM #2
Very cheaply made pala ang VIC? I was considering this in my next oil change. Surprisingly, okay pala ang Purolator and it cost cheaper than VIC.
April 3rd, 2012 09:48 PM #3
Sayang, kakabili ko lang ng OEM Toyota filter. Sino kaya may gawa ng Altis filters dito? Sa ngayon, I am on Purolator filters from Speedyfix.
- Jul 2019
- 10
July 2nd, 2019 02:34 PM #7Note : i cant seem to reply in this thread without quotting a post. hehehehe
My opinion. I never had a problem with Vic filters ive used em for years and my cars seem to be ok considering i have a 30year old car and a 20 year old pickup.
i tried using the cheaper WIN filters and that was pure ****. na notice ko na sobra taas temp ko and parang iba tunog sa makina after an old change i was really confused since galing oil change i figured na it has to be the filter i immediately change that and viola na back to normal. I think barado sya . Will never use WIN again.
- May 2017
- 2,116
July 2nd, 2019 02:51 PM #8
- Feb 2008
- 898
July 6th, 2019 08:16 AM #9
- Dec 2013
- 527
August 27th, 2019 11:27 PM #10Actually WIN filter brand is just a private brand made up by a company in the Philippines, it is one of the worst low cost filters available only in the Philippines' market just like the same aspect as CDR-King, a made up brand and outsourced from a low cost poor quality manufacturer. WIN filter brand is being made in Taiwan. The same as the other private brands like Union-Asahi imitation of Union filter and etc... There are lots of made up brands or copycat brands in the Philippines which are only targeted at the mass market of D & E which only focuses on the price. Check niyo packaging ng WIN brand filters and Union-Asahi filters both of which have a similar copied design from a specific Japanese branded filter from a very long time ago.
Tesla Philippines
