Page 11 of 14 FirstFirst ... 7891011121314 LastLast
Results 101 to 110 of 136
    Feb 2003
    #101
    *miko....Agree agree ako sa post mo.
    Thanks nga pala sa Zic oils and Baldwin filters...If you could find any oil test on ZIC UP and ZIC A pls. do share it.
    #102
    zic power diesel synthetic 10w40... cheap lang... i bought it for only 3200 pesos 20liters can.... or 160 pesos lang per liter....
    mas maganda sa caltex, castrol, mobil non synthetic, top one diesel synthetic, valvoline none synthetic, shell oils except the synthetic shell oil hindi ko pa kasi na subukan...
    sir, san ka nakabili?
    Dec 2009
    #103
    Don't worry sir jiggs,, nagtatabi na ako mga used oil hehehe... tapos papa analyze ko sa Monarc...
    UUnahin ko yan sa Petron trekker!! tpos Susunod ko si castrol,, haha...
    Lakas kasi nang marketing nila eh,, tignan ko kung tunay nga na maganda oils nila...
    sir jiggs, pag nag change oil ka, patabi at patago naman used oil mo ng ZIC UP at ZIC A,, pa analysis koh...
    #104
    Quote Originally Posted by miko101130 View Post
    miko, pwede ako magtabi ng Top1 SDO and Zic A
    Aug 2010
    #105
    i use petron trekker 15w-40 diesel oil on my pikup even on my gas fed car, ok sya kahit sa gasoline engine gamitin, kagandahan ng trekker di sya nag bi build ng sludge, runs smoother and mura lang sya 180 petot lang per liter.
    Dec 2009
    #106
    Marami choices other than the BIg three companies... try to explore other lubricants that are way much better than them, additional 50 to 100 pesos per liter pero malayo difference in quality and performance...
    Cost cutting on lubricants is never a way to save money... you're just saving up for a bigger expense later on.
    Aug 2010
    #107
    careful lang sa mga brand ng oil sir marami dyan repack lang ginagawa nila, gamit na lang kayo sa mga tried and tested, baka po mag ka sludge engine nyo, sa mga na try ko na mineral oil caltex and petron ang pina ka ok, sa synthetic mobil, royal purple and motul, stay
    away from castrol.
    #108
    i use valvoline semi-synths. so far so good naman. i prefer mobil 1 actually but it's not available everywhere
    May 2010
    #109
    for my latest change oil this month i used Repsol Inyeccion for one of my diesel car. So far so good. i also use Top1, Motul, Mobil, Castrol(only Magnatec and Edge) and Royal Purple.
    May 2005
    #110
    pag gas engine kasi hindi masyado need na robust ang oil to used.. a good semi synthetic will do, but if you're after longevity and maximum performance try to use an oil with CI-4 rating together with an SL API rating...
    Good amount of Phosphorus/calcium/moly/boron and a very good TBN reserve..
    traditional gas engine oil (SM/SN) will only have 6-8 TBN rating whereas CI-4 with SL rating will have TBN of 9-10...
    So better to use a diesel specific oil (CI-4) on gasoline engine than normal gas specific oil (SM/SN)? This will last longer?
automotive engine oils: whats your pick?
