Results 1 to 10 of 15
- Aug 2003
- 9,720
July 10th, 2005 08:00 PM #1any suggestions on how to get the oil filter off an ae92? all those oil filter wrench crap don't work at all! ayoko sana magresort sa tuhog...
July 10th, 2005 08:32 PM #2
baket hindi gumagana ang wrench?baka lang po mali ang paggamit....our mechanic never had problems with it naman kahit na sobrang sikip nang pagaklahigpit.
Tsikot Member Rank 3
- Dec 2003
- 546
July 10th, 2005 08:42 PM #3either hindi nilagyan ng oil yung rubber part ng spout ng oil filter kaya nun nanigas at naluto yung filter, kumapit yung goma sa baka ng engine block, or replacement filter gamit mo at sobrang lambot yung kaha ng oil filter kaya pag ginamitan mo ng wrench either kadena or yung solid hook, lumulobog lang at hindi kumakapit yung wrench,
kailangan talaga tuhogin yan, especially pag malambot yung oil filter at madali butasin yung filter
- Aug 2003
- 9,720
July 10th, 2005 09:23 PM #4glennsterr:baket hindi gumagana ang wrench?baka lang po mali ang paggamit....our mechanic never had problems with it naman kahit na sobrang sikip nang pagakahigpit.
July 10th, 2005 09:35 PM #5
Have you tried the fanbelt technique? Looping the fanbelt around the filter; make sure you loop it tightening more around the filter.
If all else fails, tuhugin na nga yan, messy but it gets the job done.
July 10th, 2005 11:45 PM #6
happened to me once sa fx ko. i did what Sir Ungas said the fanbelt technique but i wrapped a folded sand paper first sa filter then wrapped the fanbelt around it... and presto! tanggal ang filter hehehe... use rougher grit sand paper para mas may kapit
July 11th, 2005 12:10 AM #7
Originally Posted by Ungas
mas prefer ko pa nga gamitin ang fan belt thing ..
kaysa sa rather than wrench...mas nagamay lang cguro ako
sure mo lang tightness mo para wla sablay
sa wrench may tendency mabutas like what the some post sez
July 11th, 2005 12:17 AM #8
so in tightening a oil filter, hand tighten lang ba? gaano kahigpit? since imposible naman sukatan ng torque wrench.
July 11th, 2005 12:38 AM #9
Originally Posted by ILuvDetailing
by means of feeling na lang sa higpit ..kung feel mo mahigpit na sia
then double check ko na lang kung mag kakaroon the following day ng oil leak
if ever meron tight na lang uli ..so far ok pa naman sa akin
IMO
July 11th, 2005 01:00 AM #10
kaya bang i-hand tighten ang oil filter? kailangan ata talaga gamitan ng tool yun (chain clamp or some such), kundi baka lumuwag pa at sumirit yung langis. kulang na kulang yung leverage ng kamay e hehe
Tesla Philippines
