Results 1 to 10 of 14
- Jan 2019
- 19
November 8th, 2019 10:37 AM #1Good day nga sir.
Ask lang po sana ano yong nakabilog sa photo?
May putol po kasi. Para saan po yon?
Salamat in advance mga sir.
- 53,883
November 8th, 2019 06:25 PM #2
- Jan 2019
- 19
November 8th, 2019 09:59 PM #3
- 53,883
- Jan 2019
- 19
November 9th, 2019 09:54 AM #5
November 9th, 2019 10:10 AM #6
Toyota calls it the "vacuum transmitting valve". It may be some sort of a check valve or one-way valve.
Part 23283 in the diagram (Mid-upper-center of the diagram)
Part no.: 90925-01091 - VALVE, VACUUM TRANSMITTING, NO.3
VACUUM PIPING[ (925- )2E ] TOYOTA COROLLA [AE1#,EE1] (ASIA and MIDDLE EAST)
Function and testing:
- 53,883
November 9th, 2019 10:14 AM #7still can't see, where it connects to...
efi na lang!
heh heh.Last edited by dr. d; November 9th, 2019 at 10:19 AM.
November 9th, 2019 10:20 AM #8
It's part of the emissions system. Here's another diagram, not from a 2E but it serves the same function.
It's the part indicated as "VTV" for Vacuum Transmitting Valve.
- 53,883
November 9th, 2019 11:23 AM #10
Generally speaking, yes. Technically, no. It should flow unrestricted in one direction and slightly restricted in the other. How slightly restricted is dependent on the intended use. The engine vacuum varies widely during operation and certain pneumatic devices controlled by vacuum needs just the right amount to work properly.
Somebody can probably explain it more eloquently:
In one direction the VTV's are supposed to restrict, but NOT prevent flow. In the other direction, it should allow unrestricted air flow. If the flow one way is stopped, then the emissions system the VTV is associated with won't work properly.
