Results 1 to 9 of 9
- Oct 2009
- 179
June 20th, 2014 05:19 PM #1Help mga sir, bakit ganon un accelerator pedal minsan malambot tapakan at responsive pero minsan matigas at parang ang bagal umandar, minsan din kapag unang tapak mga halfway matigas pero kapag mga 3/4 na un tapak biglang lumalambot at biglang responsive. Nasa cable kaya ito? Wala naman problem kapag nasa higher gears, hindi naman sliding, kasi once na naramdaman ko na lumambot na un pedal bigla ng umaarangkada minsan sin malambot din agad sa first gear.
Thanks.
- Oct 2009
- 179
June 20th, 2014 05:30 PM #3
Check by opening and closing the throttle directly for binding, then check and lubricate the throttle cable inside the tube
Nakiki wi-fi lang
- Oct 2009
- 179
June 20th, 2014 05:45 PM #4
June 20th, 2014 05:47 PM #5
Hehehe thanks. But it will be a "far away call". Btt carb cleaner usually takes care of that
Nakiki wi-fi lang
- Oct 2009
- 2,271
June 21st, 2014 01:58 PM #6try nyo po muna tanggalin ung cable dun sa carb at subukan pihitin ng kamay kung sakaling mag normal ang pag hatak..
malamang sa cable po yan sir..
- Jul 2010
- 570
June 24th, 2014 02:08 PM #7
- Jun 2006
- 1,139
June 24th, 2014 02:43 PM #8Usually a snapped single strand inside the cable housing is the cause of hard to press accelerator. Gumagasgas na sa luob yan, paltn mo na at bka matuluyan pamhabang gamit mo.
- Oct 2009
- 179
June 24th, 2014 04:18 PM #9Salamat mga sir, papaltan ko na ang accelerator cable, pero mga sir paano kung wala ng available na cable, pwede bang pagawan nalang ito ng cable? Medyo mahirap na kasi ang parts nitong 3 cylinder f8c engine. Thanks.
