Results 1 to 7 of 7
- Oct 2007
- 56
July 19th, 2010 01:56 PM #1How does one remove excess engine oil on a 4d56 engine?I recently had an oil change.Level was correct when I had it done, but when I checked the following morning the level was past the maximum. Kailangan po ba idaan mismo sa oil pan ang pagbawas nito?Sinubukan ko po kasi kung saan naglalagay ng oil sa ibabaw ng makina pero ang dami pala components na nakaharang sa loob ng makina.Di ko maabot yung sa oil mismo.
- Oct 2007
- 56
- Jul 2003
- 573
- Jan 2008
- 4,726
July 19th, 2010 10:07 PM #5bro read your manual.. to measure your engine oil level, make sure the vehicle is on level surface.. start the engine for a few minutes.. turn off the engine and measure the oil level..
July 20th, 2010 09:55 AM #6
Actually, it's more accurate to keep the engine off when measuring the oil level.
When you turn the engine on, the oil circulates into the PCV and oil pump. It takes a while for it to get back down into the crank. It's best to check with the engine completely cold, to make sure the oil has settled as much as possible.
July 20th, 2010 08:10 PM #7
may nabibiling hand pump suction hose sa ace or diy worth p100 kung gusto mo. fits also sa oil dipstick tube. bombahin lang by hand.
Tesla Philippines
