Results 1 to 4 of 4
- Jan 2009
- 163
May 10th, 2014 05:20 PM #1Good day mga guru,
ask ko lang regarding sa problem ng grand starex ko 08 model TCI bale ang nangyari nakapark lang ung auto nung gagamitin ko bigla di na gumana ung temperature needle nya ginawa ko pinalitan ko ng water sensor kaso di pa din gumana.
any advise kung san ang problema cavite area po ako. ayaw galawin ng electrician dito kasi electronics daw po.
salamat ng marami
May 12th, 2014 01:00 PM #2
may temp sending unit yan para sa gauge (1 terminal malapit sa upper radiator hose sa may engine).
May 13th, 2014 09:56 PM #3
Yes baka maling sensor ang napalitan mo. Usually there are 2. 1 thermoswitch and 1 temp sending unit. Highly unlikely na gauge problem since its a fairly new model. Although if replacement of the sensor doesn't work, its probably the gauge cluster or wiring. I could recommend a good electrician however his shop is in Banawe.
- Jan 2009
- 163
May 28th, 2014 11:19 AM #4
Tesla Philippines
