Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 62
    #41
    ^ the manual's instructions are in general terms. Just like any other loosely translated chinese literature
    So it's ok to leave it resting atop the engine bay while it's operating?
    I'll just use it for topping-up purposes only
    Aug 2012
    #42
    Yes, you can keep it atop the engine bay.
    SON-10A is old model. The new models are SON-10A+ and SON-20A+ with improved charging and enclosure.
    #43
    My battery can't start my car anymore. Happened just 2 hours ago. I was able to drive home with the help of my powerbank with jumpstart function.
    I'd rather not go out tonight to get a new battery. My plan is to start it up tomorrow morning again with the powerbank then drive over to a battery dealer. Right now, the car is parked at home with alarm on and doors locked. Is there any chance that the battery will totally drain overnight because of the alarm being left on? If it totally drains, will I still be able to jumpstart with a powerbank?
    By the way, nag-check engine bigla after kong i-start. Side effect ba ito ng pag-jumpstart?
    your battery can't hold its charge for long periods (longer than, say, 15 minutes) anymore, even if it is not connected to anything.
    patay na po siya.
    you can probably still start the car, with the use of your powerbank.
    #44
    yespo.
    the manual is written for "worst case scenarios".
    Jun 2015
    #45
    Quote Originally Posted by red_one View Post
    Is the son-20a any good? I'm eyeing a Vgate which is around 3.8k that seems to be similar in operation but still cheaper than a Ctek. Ok na ba ito for maintenance purposes o mas maigi pa ring mag-invest sa Vgate o Ctek?
    Aug 2012
    #46
    Depends on what you are looking for. SON-20A+ is Automatic 3-stage 20A Charger.
    Since you have the budget, I suggest this one. Automatic Smart 7-stage 8A Battery Charger Desulfator Maintainer with Reverse Pulse. Just P3,000.
    Jun 2015
    #47
    patay na po siya.
    Yes, the battery was indeed dying. Since it's a weekend car, I waited 6 days to buy a replacement. By then, the battery voltage was already down to 8V. Powerbank was still able to start it up but since there was a bit of hesitation in cranking, I kept it running and drove to the nearest battery dealer pronto.
    Jun 2015
    #48
    Depends on what you are looking for. SON-20A+ is 3-stage charger.
    Thanks, I'll add this to my wishlist, hehe.
    Dec 2009
    #49
    Do i need to disconnect the battery in order to safely and effectively use this digital battery charger
    is it safe to leave it on the engine bay while it's charging the car battery?
    How long does it need to recharge the battery?
    If its for the first time you will use that contraption, its safe to remove a battery terminal (preferably the red terminal or the positive).
    Its better safe than sorry, that thing you bought could be defective out of the box (shorted). Disconnecting the positive or red terminal to the battery isolate your cars electrical and electronic circuits from the battery and the new gadget you will attach to your battery.
    Negative terminal shouldnt be disconnected because its always connected to the ground and the body of all cars are good ground. Should the new gadget you have bought is defective or shorted the ground or the body of your car is a good place to absorb the high current that could flow
    The worst case scenario when theres poor grounding, the battery can explode in your face. Batteries contain acids that could blind you when it reach your eyes
    Sent from my GT-P3110 using Tsikot Forums mobile app
    #50
    I finally Tried it yesterday [emoji4]
    pag pumapalo na ng 0 (intermittently) fully charged na iyong batt? Very unclead iyong manual about this
    Ps pls excuse the dusty engine bay 🐷
Stupid question about dead car battery (car wouldn't start)
