Results 1 to 4 of 4
    Mar 2013
    hi guys, your advice on this please.,dati kasing my subwoofers yung auto ko, ngayon nung tinangal naging static na.,everytime na magrerev maririnig mo na sumasabay din siya or even when neutral meron pa rin.i went to an autoshop and was advised to buy this "relay thing kung ano man yun" pero walang guarantee na mafifix.,ang sabi sa akin new stereo na daw.,medyo duda lang ako na baka para makabenta lang or could it be fixed by putting or removing some wires?thank you
    Jul 2010
    Quote Originally Posted by Raff Gutierrez View Post
    Pwede rin relay ilagay kung luma na wiring ng kotse or luma na rin contact ng ignition switch. Pag on ng ignbition switch ay activated na yun relay. Direct kasi kukuha ng wiring connection from battery papunta sa stereo mo. So, wala na loose connection at hiwalay ng yun line ng stereo sa ignition coil. Yun ignition coil nagbibigay ng ingay sa stereo. Siguraduhin may fuse din ilagay sa line ng stereo. Iwas sunog kotse.
    Feb 2009
    your charging system might have a problem with the rectifier assembly. if it makes too much RFI (radio frequency interference) and EMI (electromagnetic interference), you can try to reduce this radio noise by installing a condenser or capacitor at the output or battery terminal of the alternator. this noise you are experiencing is proportionate to the engine speed. try removing the alternator belt and operate the engine while listening to the radio noise. if it does not make the same noise, the alternator has a bad or a couple of bad diodes
    Jun 2007
    na experience ko na yan....
    kailangan ng palitan ng bago yung carbon sa alternator.
    papalitan nyo na sir....baka matula kayo sakin na bigla na lang tumirik sa gitna ng kalasada.
static stereo help
