Results 1 to 8 of 8
- Jan 2018
- 21
January 24th, 2018 12:53 PM #1tsikoters, ask ko lang kung anong magandang ilagay na pangbalot sa wire. kasi yung wire ng starter ko medyo malapit sa exhaust manifold. kahit nilayo ko na medyo nalulusaw parin yung balot ng wire.
- Mar 2010
- 2,270
January 24th, 2018 05:12 PM #2
January 24th, 2018 05:32 PM #3
degraded na siguro, need to change. degraded wires have increased resistance, hence with same current it will heat up abit.
hmm interesting, my starter is located near the intake manifold(front side), is your vehicle a honda?
January 24th, 2018 06:08 PM #4
3M glass cloth electrical tape. meron yan sa hardware stores. kung wala sa home depot or wilcon sure na meron. pero you need to secure the ends with either metal tie wrap (di pwede plastic kasi sabi mo mainit), hose clamp or lock wire para hindi mag-fray yung ends.
- 53,883
January 24th, 2018 10:39 PM #5
- Jan 2018
- 21
January 25th, 2018 10:38 AM #6i already did that and added some plastic tubing that i wrap around the wire which protect the heat from the manifold, but still the plastic tubing melted a little bit. so i will try now some other thermal heat shield thing mention above. thanks
[QUOTE=Flipo;2924324]Hanap ka ng 3M fiber glass cloth, yun ang gamit namin sa power, oil and gas industry, etc.[/QUOTE
will try asap... thanks
- Jan 2018
- 21
January 25th, 2018 10:40 AM #7
- 53,883
January 25th, 2018 09:59 PM #8[QUOTE=almighty2018;2924536]i already did that and added some plastic tubing that i wrap around the wire which protect the heat from the manifold, but still the plastic tubing melted a little bit. so i will try now some other thermal heat shield thing mention above. thanks
is your starter cable original?
the revos i have seen, did not seem to have this problem. or, are their owners plain lucky?
Tesla Philippines
