Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
    #21
    the starter interacts with the flywheel. i do not think the clutch has anything to do with the starter.
    Sep 2016
    #22
    How about the ignition switch? Well, if it has none and the battery is in good condition too. It's just either between the starter and the flywheel.
    Feb 2009
    #23
    is it possible for you to record and post the sound recording? there are different stater signature sounds and there are abnormal starter sounds. some tuned ears can identify the symptom you are experiencing
    Sep 2016
    #24
    Yes sir, my pleasure!
    This is the link of my youtube video; This is my original denso starter. We had it replaced with a surplus original denso starter for hilux a week ago and I will upload tomorrow how the new starter sounds.
    Toyota Hilux 1KD-FTV grinding noise when cranking - YouTube
    And let's try to compare them tomorrow, sir. I greatly appreciate your help!
    Feb 2009
    #25
    Quote Originally Posted by Offroad_Goals View Post
    Sounds like the overrunning clutch(one way clutch) of the starter drive gear. It has low spots in the engagement race surface
    Sep 2016
    #26
    Is it this one, sir? Can you see the encircled part in the photo, sir?
    Feb 2009
    #27
    Yes. Check the rollers for out of round and check the springs that push the rollers to engage
    Oct 2014
    #28
    Where usually or who i need to see to check starters? Is it an auto electrician or any mechanic? Thanks
    #29
    Quote Originally Posted by Gian Paulo View Post
    either, po.
    starter technology is "de cajon". except for a few points, they are much all the same.
Starter grinding noise
