Results 1 to 10 of 14
August 11th, 2017 12:02 PM #1
2014 Vios 1.5g Manual
Good morning mga Sir!
Anyone here nakaexperience yung habang nakafullstop sa traffic.. nakaneutral.. biglang magquickshutdown ang buong auto.. lights, aircon, engine (basta mga naka ON) then magturn on agad naman lahat (dahil siguro nakaengage yung key sa pag on) PWERA ang engine? Parang yung biglang nagrestart na computer..
Three times na nangyari.. Kapag naka neutral at stop (luckily).. Battery is still new.. Walang naman warning sa indicator lights ng dashboard.. bagong tune-up din ang auto.. everything is normal kung tutuusin.. nakakaworry lang yung may sumisingit na ganyang incident (di siya everyday) pag minsan..
Sensya na.. Not sure kung sensor related siya or anuman.. TIA..
- May 2011
- 481
August 11th, 2017 02:39 PM #3That would be loose power cable or loose ground wire. The most common cause is corrosion on the cable clamps. Test but running the engine and do a wiggle test on the battery cables and the negative cable to the body and to the engine block.
August 11th, 2017 02:53 PM #4
August 11th, 2017 03:00 PM #5
If the engine's been running, removing the battery should keep it running... albeit at a slightly lower RPM. My guess would be a loose or defective main relay or main fuse.
August 11th, 2017 03:21 PM #6
- May 2011
- 481
August 11th, 2017 03:48 PM #7Whatever you do
DO NOT DISCONNECT THE BATTERY WITH THE IGNITION SWITCH ON OR WITH THE ENGINE RUNNING!
The voltage spike or surge is not friendly to your car's electronics including the PCM.
August 13th, 2017 06:30 PM #8
Will OBD (?) scanner be effective to diagnose the problem? I'm not sure if it is mechanical or electrical (most likely).. Will double check the connecttions sa battery too..
- 53,883
August 13th, 2017 07:21 PM #9
- May 2011
- 481
August 14th, 2017 04:53 AM #10
