Results 1 to 6 of 6
    newbie question po, madali po ba ipaayos yung wiring sa radiator fan, lagi kase sya nakabukas kahit close yung aircon.
    mazda 3 po auto ko. Thanks
    Feb 2009
    Quote Originally Posted by mudspit View Post
    is your airconditioner working properly? is your hi/lo pressure switch connected this is located near the firewall on the passenger side)?
    . unplug and try connecting a 4 kilo ohms resistor between terminals of the coolant sensor terminal. this is located next to the thermostat housing
    Chief mudspit,
    Either the engine coolant temperature sensor or the radiator fan relay are defective already. Have checked / replaced by a specialist.
    thanks sirs, aircon is working fine po, wala po ako alam talaga kase sa sasakyan. any idea po how much gastos dito? and aircon specialist ko ba dadalhin or electrician? sorry for such noob questions
    Feb 2009
    have the pcm scanned both cold engine and normal engine temperature while the engine is running, ask for the pcm readout of the engine coolant temperature sensor (ECT) if the sensor is not giving the right signal, the pcm goes into safe mode and runs the radiator fan continuously
    where can i take my car to have it tested? meron ba nyan sa mga gasoline service stations? also kahit close ang aricon, tumatakbo yung fan
radiator fan always on: help
