Results 1 to 10 of 12
September 20th, 2013 06:49 PM #1
Sir/Madam,
Any idea why is it may mga plug in volt meter na may naka note na When engine running (do not drive),the LED dispaly: like the one on this ad?
BNEW car volt meter Electric Voltage meter for car - For Sale Philippines - 22687872
Thanks a bunch
September 20th, 2013 06:53 PM #2
September 20th, 2013 07:03 PM #3
Hirap intindihin ng ad nya na minsan ma misinterpret mo pa na bawal ba yan habang tumatakbo car?
Naghahanap lang ako ng makakalikot over the weekend, just saw this para shortcut sana kaso parang feel ko rin yung naka panelLast edited by jodski; September 20th, 2013 at 07:07 PM. Reason: Added more details
- Jul 2010
- 570
- 53,883
September 20th, 2013 10:19 PM #5i think it means, the gadget is for reading battery voltage and not alternator voltage.
with the engine not running, the gadget reads battery voltage, which goes lower than 12 volts as the battery gets weaker.
with the engine running, the gadget will read not the battery's output, but the alternator's output (of at least 13 something volts), thus giving you the mistaken impression that your battery is strong even as it is about to die if not yet dead.
but if the alternator is defective, then, with the engine running, the gadget will register a lower voltage...
chinese translators are sometimes entertaining..Last edited by dr. d; September 20th, 2013 at 10:26 PM.
- Mar 2009
- 823
September 20th, 2013 10:46 PM #6when the key is in the "on position" the meter should be displaying 12 (12 volt) pure battery power and when you crank/started the engine(but you are idle hence not driving), it should display a higher voltage than 12 but not more than 14(12 volt)
it shows the voltage of the alternator when your engine is started and your battery voltage when your car key is on the "on position"
when your driving the volt meter must display 13-14 volt reading(it means your alternator is good and not withdrawing the battery of your car)
24volt are for heavy duty trucks
by the way when you use that plug and play volt meter, it should be inserted on the main car plug(in the front dashboard) without any other gadgets or extension plugged in so you may have an accurate reading
forgot to add if it is reading more than 14 on a 12v car it means your battery is being over charge and it might explode or overheat your electrical system
September 21st, 2013 10:10 PM #8
hi, please enlighten me: i have this kind of cig plug volt meter bought at concorde. true, it reads at 11.9v-12.1v before ignition; though when idle, it reads between 14.1v-14.5v. thus i'm a bit worried about the overcharging and overheating. kindly clarify. thanks
- Nov 2009
- 3,503
September 22nd, 2013 01:25 AM #914.5 is a bit high especially for AGM types. Those plugins have large deviation from real voltage, add to that cig plugs contacts may become loose. If you want to be sure, use a Fluke tester or some lab-calibrated tester as reference voltage.
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 22nd, 2013 01:39 AM #10Most of us wont have access to a lab calibrated tester. But I agree that those plug in types are not 100% accurate. Best to get a tester and check the voltage at the battery.
