Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    May 2013
    hi guys,
    my low beam is not working pero if i flash or use the high beam, ok naman. isang pang observation ko, kapag nag flash ako, mihindi sumasara yun ilaw. nakikita ko na lang na bukas yun ilaw pag nasa parking area na. switching the light on and off wont do it, kelangan laruin yun flash para mag sara. could it be the switch? headlight is H4 btw. thanks!
    sent it to RAE last month, wires lang daw problema, now ganun na naman.
    Feb 2009
    Do you have add-ons to the light circuits like aftermarket fig lights ? Try checking the headlight relay first
    Posted through phlpost.gov.ph
    Aug 2012
    Quote Originally Posted by gutz_3110 View Post
    hi guys,
    It could be the relay / fuse na nabasa. Ganyan din prob ko pero high beam naman nawawala. Dati mga twice ako pabalik balik sa electrician, nung naulit at nawala na naman ako na tumira at nag-ayos at nalaman ko ang problem ay nababasa ang relay pag nagka-carwash ako at power spray sa hood. Natatalsikan pala sa loob. So ako na nag repair ng relay socket at palit relay na rin kung sira.
    Highbeam / Flasher I think iisa lang kaya wala ka prob.
    Kung panay ganyan, baka same problem ko rin. Alamin mo kung naka relay ka na at check mo yung socket relay / relay kung medyo nagpu-pulbos, ibig sabihin nun (for me ha) nababasa.
    HTH
    Sep 2005
    baka madumi lang yung contact point.. or baka sunog.. anong car?? pag honda pinapalitan yung buong assembly..
    isang headlight lang, o parehong headlights ang hindi sumasara?
    if both lights, baka switch o relay nga.
    May 2013
    hi,
    parehong headlights ang wala kapag low beam. dyahe naman mag high beam baka ma bad trip kasalubong hehe no other add on lights like fog lights. papa check ko relay sa saturday, sana yun lang sira. mahal pala yun switch, assembly ang bibilhin.
    may chance ba nu pundido din ang ilaw? balak ko din kasi magpalit ng bulb, para isahan na.
    May 2013
    civic vtec 3, bro.
    Pundido na yan Brader.
    Nov 2013
    hi guys,
    Sir, malamang yun switch n ng headlight sa loob ng ilalim ng steering, ang may sira, happened to my honda city 05, i got high beam(both), but no low beam, went to casa c they replaced the whole thing , cost around 2.5k
    Posted via Tsikot Mobile App
    Aug 2012
    remove the bulbs and connect directly to the car battery or 12V DC power. this will rule out if pundido ang ilaw or not.
Low Beam not working but high beam is fine
