Results 1 to 8 of 8
February 6th, 2019 08:17 PM #1
Delayed yung power window sa passenger side likod ng driver.
Pagka start ng engine, need to hold the window button (not sure what the term is) for like 20-40 seconds bago bumaba. Pero once bumaba na wala namang problema na. The next day babalik ulit yung delay ang much worse is pag mga 2-3 days di nagamit yung oto minsan ayaw talaga bumaba.
Any solution for this? baka kelangan lang ng pang pa "dulas" sa side ng window?
February 6th, 2019 08:53 PM #2
I think it's sticking and/or the motor or mechanism is on its way out. Try first using silicone spray along the window channels. That might prevent the window from sticking. This is probably just a temporary fix and the long term solution is likely to determine if the window mechanism also needs lubrication or if the motor is dying.
- Apr 2008
- 6,235
February 10th, 2019 10:55 AM #3Agree that it is most likely the motor. Experienced this with the Revo.
- Oct 2009
- 2,271
February 10th, 2019 12:38 PM #4common ung rubber spray ka nalang ng shampoo na may kahalong tubig baka masyado ng madumi or matigas ung goma
February 10th, 2019 04:42 PM #5
*Gti
Kahit yung isang window lang ang may problema? Does it mean, one motor per window?
- Apr 2008
- 6,235
February 10th, 2019 04:51 PM #6Yes, one motor per window.
I have tried the lubricant. Elevo brand. It helps, if sticky rubber seals is the problem. But eventually for me, the window stopped working altogether. For the driver side window, it was the motor. When the passenger side stopped working another time, motor was fine upon checking. Turned out the switch was to blame.
- Feb 2019
- 2
February 12th, 2019 10:23 AM #8same problem din pero ung sakin lahat ng windows... May delay na 3-5 minutes bago gumana at yun ay kapag nagdadrive na ako. failing motor rin kaya to?
Tesla Philippines
