Results 1 to 10 of 19
- Oct 2014
- 37
December 2nd, 2020 10:10 PM #1Good evening po sa lahat. Pahingi po ako ng tulong. I have a 2017 Honda HRV. Yung fog lights ko po parehong biglang ayaw umandar nung isang araw. Pinacheck ko sabi ok daw ung bulbs so pinalitan ng bagong fuse. Umandar na ung lights. Nung gabi na ginamit ko na siya pero mga 20 min lang biglang ayaw na umandar ulit. Ano po kaya ung pwedeng problema? Naka aftermarket po ako na LED H11 pala na nagamit ko naman for 5 months without a problem tapos ganun po nangyari. Thank you po.
- Mar 2008
- 53,883
December 2nd, 2020 10:12 PM #2
- Oct 2014
- 37
December 2nd, 2020 10:15 PM #3
- Mar 2008
- 53,883
December 2nd, 2020 10:18 PM #4ask an expert to look at your set-up, po.
fuse... wiring... housing...
if the (stock, i assume) fuse keeps blowing kasi, your lights are probably drawing more current than what the car's wiring was designed for.
you might have to upgrade everything and not just the fuse.
btw,
i noticed that many car drivers use their bumper lights and not their headlights.
are they aware that sometimes, them bumper lights actually generate more glare than the stock headlights?Last edited by dr. d; December 2nd, 2020 at 10:34 PM.
- Oct 2014
- 37
December 2nd, 2020 10:40 PM #5
- Mar 2008
- 53,883
December 2nd, 2020 10:52 PM #6
December 2nd, 2020 10:30 PM #7
- Oct 2014
- 37
December 2nd, 2020 10:41 PM #8
Tsikot Member Rank 2
- Jun 2005
- 3,774
December 3rd, 2020 12:10 AM #9Simplest answer, go back to stock. If fuse dont blow, led bulbs have a problem.
If fuse blows, go get yourself an electrician.
My money is on defective LED bulbs.
Sent from my MI MAX 2 using Tapatalk
- Jun 2004
- 1,311
December 3rd, 2020 01:11 AM #10I am assuming the LED bulbs were plug and play and no other electrical wires were spliced? If yes I would suggest going back to regular/stock halogen bulbs and see if the problem goes away. As you mentioned these are fog lights then I do not see any benefit for using LED bulbs, ideally real fog lights are yellow halogen bulbs. This is just my opinion though and I could be wrong as some newer cars might have LED as "driving light/fog lamps".
Tesla Philippines
