Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    May 2009
    anyone who can tell kung yung switch ba o sensor yung isa na single contact na nasa cylinder head ng 4d56. the double contact is the temperature sender while yung part in question have never been tapped into the circuit of the vehicle since acquisition. ngayon ko lang napansin. its location is just beside the engine hanger.
    hijacked this photo from pocuk.com
    http://i217.photobucket.com/albums/c...t/DSC01597.jpg
    some say it's a temp sensor for the fuel system during cold starts, temp sensor for the O/D of the A/T, etc.
    did a resistance test myself. zero ohms (ON) when cold, XXX ohms when hot (forgot the reading, sorry). i am planning to install a thermo switch connected with the aux fan in place of this sensor. my auxiliary fan is tapped to the A/C at present.
    tia
    May 2009
    the sensor on the right of the pic is my inquiry.
    Quote Originally Posted by miked View Post
    not familiar with it, but you can check continuity to ground. pag walang continuity pag cold and magkaroon pag uminit na then it's a thermo switch. you can also check kung meron naka stamp na temperature sa body ng sensor.
    May 2009
    baliktad eh. continuous (on) when cold. increasing resistance when getting hot. thus hindi sya switch. i'm searching for a switch with the same thread pattern in the range of 90-95 or 95-100C that will fit in the same location. MB435745 at MB660664 pa lang ang nahahanap ko sa net kaso not the same diameter afaik.
    Jan 2009
    Based on some bit of research, the two-prong temp sensor on the left is what tells the glow control module how long the glow plugs should warm up (lower measured coolant temp = cold engine = longer glow plug operation, and vice versa). The single-prong temp sensor on the right is supposed to be the one that's connected to the dashboard temp gauge.
    The following shop manual might help. Refer to pages 44, 48 and 50 of the document: http://www.google.com.ph/url?sa=t&rc...TZMpOY7pO3gwpg
    Hey guys, buhayin ko lang yung thread. Lately, hindi na umaangat yung temp gauge ko. I need to know the location of the coolant temp sensor. Itest ko kung eto yung sira, or yung gauge na mismo.
    TIA.
    Jan 2008
    kung single wire yung B, yan yung temp sensor, yung A para sa glow plug control
    pwede mo i-dikit sa ground yang wire na yan to check yung buo yung gauge mo sa panel, dikit mo lang saglit sisipa yung gauge nyan
    Two-wire sya sir. Btw, my car is Adventure diesel.
    Jan 2008
    may isa pa dun sa gilid (left side).. try to test the resistance of the sensor baka open na yan or place a jumper wire dun sa connector and check kung aangat yung gauge mo
    Left side ng engine sir? Malapit ba dun sa lower rad hose (near alternator)?
thermo switch or temperature sender on a 4d56
