Results 21 to 30 of 55
Does a voltmeter (using the cigarette lighter plug) help us determine the health of the car battery?
- May 2009
- 93
March 12th, 2019 11:17 AM #21Suggest that you invest on a good voltmeter ( not expensive nowadays) and a good battery charger specially those using automatic transmission to avoid hassle on the road. Maintain your battery charge at least once a month and monitor your voltage while charging. You will notice amperage going down and voltage going up as it approach full charge. I normally keep the voltage between 14.5 to 15 V for a full charge battery.
- May 2017
- 2,116
March 12th, 2019 01:06 PM #22
- Jan 2019
- 11
March 12th, 2019 03:52 PM #23Sa brand new fortuner ko 1 year lang bumigay na battery. Parang generic lang kasi. Nagpalit ako motolite 2 years ko na gamit so far so good. Battery life should be 4-5 years.
March 12th, 2019 06:33 PM #24
CTek battery chargers are good ... They're on the expensive side already ... You just connect it to the battery in the car ... No need to remove the battery ... Just don't start the vehicle ... You can also look for generic smart car battery chargers on olx lazada or aliexpress ... Make sure it's "smart" meaning it trickle charges when almost full, protects from overcharging, and detects reverse polarity ...
Normal battery life in this country is 2-3 years ...
- May 2017
- 2,116
March 13th, 2019 10:53 AM #25
March 13th, 2019 11:36 AM #26
Nope. Just hook the CTEK comfort connect that comes w/ your set onto the terminal bolts. PlugNplay. Buy 1 for each car you have. They're around Php300. Comes in 1/4 & 3/8" eyelets. Blade & some online vendors carry em.
CTEK Comfort Connect Eyelet Red buy and offers on Waveinn
- May 2017
- 2,116
- Oct 2012
- 4,851
March 13th, 2019 04:52 PM #28
March 14th, 2019 01:31 AM #29
- 53,883
March 14th, 2019 02:28 AM #30i read it before i start the engine, with the key on ACC.
once the engine starts, the reading is now a reflection of the alternator's performance, and not the battery's.
i want to read it during the cranking period, but i simply can't read it... probably something to do with my eyes and the gadget's design...
