Results 1 to 5 of 5
Threaded View
- Nov 2009
- 3,503
July 7th, 2013 11:31 PM #5Sir, check mo sa actual kung may naka crimp na wire. I used a tester to verify pin#8 and its consistent with my research.
Pin Signal Description
1 CHECK
2 J1850 Bus+
4 CGND Chassis ground
5 SGND Signal ground
6 CAN High J-2284
7 K-LINE (ISO 9141-2 and ISO/DIS 14230-4)
8 Ignition ON
9 ABS
10 J1850 Bus-
11 Adjust Switch
12 SCI TX
13 SCI RX
14 CAN Low J-2284
15 ISO 9141-2 L-LINE (ISO 9141-2 and ISO/DIS 14230-4)
16 +12v StorageBattery power
Actually nasimulan ko na yung zener regulator hindi lang stable, kelangan lagyan ko ng timer for delay. Iniisip ko pa kung comparator or NAND gates kaso natatamad ako, no time eh..hehe
BTW, im already using temporary(temperament kapag tinamad, lol) 3-position rocker switch.
Toggle with key ON -- OFF -- Toggle with park lights
Upper switch for DRL, while lower sw reserved for rear DRL/fog.
Tesla Philippines
