Results 1 to 5 of 5
- Aug 2010
- 38
May 15th, 2013 06:52 PM #1i just replaced my clutch assembly (disk/plate/release bearing) and done regular change oil last weekend but eventually i got engine check error P0113 and P0135 which indicates air temperature sensor voltage is too high and error on heater sensor. I tried to reset the engine check error by removing the terminals of the battery then drained it for 20minutes. But I still get engine check error indicator. My engine become and warmer than the usual. help pls!
Thanks and cheers!
villhen
- Mar 2009
- 184
May 15th, 2013 07:02 PM #2What's your car? I would check the connections to the sensors first, and go from there. If it persists, I would ask the mechanic how he did the job. Sometimes, sensors can be sprayed with electronic contact cleaners, but if doesn't work, you need to replace them. I would be wary of the mechanic who touched your car though having brought in a perfectly working car, and driving out with some kind of problem.
- Aug 2010
- 38
May 16th, 2013 12:06 PM #3Honda City IDSI 2004 Manual yung car ko. Baka may idea kayo sa engine check codes.
Eto yung lumabas sakin:
P0113 - Intake Air Temperature Circuit High Input
P0135 - Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
May 20th, 2013 05:19 PM #4
- Jul 2010
- 570
May 22nd, 2013 09:35 AM #5Tanungin mo yun mechanic anong mga sensor connector nabunot niya nun magbaba siya ng transmission? Meron lang siyang hindi naibalik. Hindi mag sinungaling ang ecu.
