Results 1 to 10 of 12
May 22nd, 2012 12:38 AM #1
My UltraGauge (UG) arrived in the mail this afternoon. It took me a while to figure out where to put it, as it can't be mounted where my ScanGaugeII was (under the A/C controls). Anyway, planning, installation, and configuration of the gauges took about an hour and a half.
This is what I had to start with. The fog light switch used to be in the center and I had to move it to the left-most slot to give room for the UG.
Stuck some 3M Dual Lock fasteners on one of the blanking panel and behind the UG mounting bracket.
Attached the bracket.
Mounted the UG on the bracket and powered up (connected to the car's OBD-II/DLC connector)
I routed the cable in a way so it won't get pinched by the door when it is closed. It goes down inside the weather strip, towards the MICU/fuse box, went under the steering column, and finally to the DLC connector. Tidied up a bit with a few zip ties.
Close up.
Total investment: $69 + S&H + Local Taxes
UltraGauge Site: UltraGauge Automotive Information Center and OBDII Scan Tool
I'll try to write a mini review soon.
April 8th, 2016 03:46 PM #4
Musta ultra gauge mo bro? Pwede ba mabilad sa araw? Planning to get mine.
Sent from my GT-I9505 using Tapatalk
April 8th, 2016 10:14 PM #5
April 8th, 2016 10:25 PM #6
April 9th, 2016 01:29 PM #7
When I sold my Civic, my UltraGauge fell into disuse. The Innova is not OBD-II compliant so the UG doesn't work on it.
April 9th, 2016 02:26 PM #8
para madali try mo bili sa amazon tapos padala mo via johnny air cargo. i tried this recently and in a week's time nakuha ko naman iyong purchase ko hassle free
actually ganito siguro gagawin ko kung i-push through ko bili ng blue driver obd2 blue tooth scanner. i'm just not sure yet if it works on the monty seamlessly
April 9th, 2016 04:35 PM #9
April 9th, 2016 04:41 PM #10
