Results 1 to 10 of 23
- May 2017
- 2,116
January 27th, 2019 12:03 AM #1My Montero 2012 shows in my battery tester gadget the ripple test of 0.480 V. Is this normal or is it a bad sign?
Sometimes when I am in the NLEX with speed of around 90-100, there is a noise, looks like coming from the aircon belt, but when I turn-off the aircon, the noise disappears immediately. I don't know if this is related to the high ripple that I get from the car battery tester.
Any helpful comments is highly appreciated!
- 483
January 27th, 2019 12:33 AM #2This is a ripple check on the Mirage, got 150mV(0.15V). You might want to have the diodes checked on your alternator.
- May 2017
- 2,116
January 27th, 2019 07:34 PM #3
- May 2017
- 2,116
January 27th, 2019 08:45 PM #4Hmm, now I used a Digital Multimeter and placed it in the AC symbol and choose option 200 (not the option 700). The DMM is now showing 30mv which is normal.
I watched a video in Youtube, and the person said that some people say over 50mv is the limit for normal ripple while other people say that the limit is now 100mv on newer cars.
I don't know but it looks like if my DHC car battery tester gadget is showing 0.30V it means 30mv and not 300mv....... Mukhang mali ang decimal placing niya
- Jan 2008
- 4,726
January 27th, 2019 08:45 PM #5
- May 2017
- 2,116
- May 2017
- 2,116
January 27th, 2019 09:18 PM #7
January 28th, 2019 12:07 AM #8
do you read your car alternators ripple while the car is stationary and while the aircon is on or off?
at stationary the rpm is just below 1000rpm which is way below the rpm at 90-100kph which is a tad below 2000rpm so that means your engine works harder during high speed so i believe that causes the noise you are complaining about
turning off the aircon at that speed disengage the compressor of the AC..so when you turn off the aircon then you lighten the load of the engine
0.48V is close to 1/2 a volt which is relatively small voltage over the total output voltage of 13.5V or higher from the alternator
the ripple voltage is typically small simply because its the average voltage measurement from the up (charging cycle of the capacitor) and down (discharging cycle of the capacitor) voltage cycle the cars electrical system generate converting AC to DC (rectifier circuit)
a halfwave rectifier normally has a higher ripple than a fullwave rectifier. its not just the diode you need to check when it comes to rectifier circuit, you also need to check the capacitor.
a poor capacitor or faulty one will normally display a high ripple voltage because its the job of the capacitor to refine the DC voltage that will charge the battery of your car
Sent from my ASUS Chromebook C202SA using TapatalkLast edited by kisshmet; January 28th, 2019 at 01:31 AM.
- May 2017
- 2,116
January 28th, 2019 09:51 PM #9
- Jan 2008
- 4,726
January 28th, 2019 10:11 PM #10
Tesla Philippines
