Results 1 to 10 of 14
    Jan 2009
    The burnt smell could be coming from the under-dash fuse box. The switch stalks don't normally carry a large enough current to cause any burning. But if it did, the relay it is triggering could be the problem.
    Jul 2016
    https://www.tsikot.com/forums/honda-...working-97978/
    May 2011
    the fuse to the headlight is usually rated at 15 amps (blue fuse). if you have the ability to measure the current to the headlight circuit it would be helpful. if the current is too high there is an overload. if the current is low, there is high resistance in the circuit that is causing the heat build up.
    May 2011
    the OEM headlamp was designed to be at 60 watts, so, at the nominal 12 volt system, it would be drawing at about 5 amperes each.
    Airbag canister smell?
    Oct 2009
    sa akin dati ung fuse socket ang nasunog kapag maluwag ung socket nag iinit talaga at malamang sa pagmulan ng sunog.check mo mga fuses baka may mga maluluwag na fuse dun sa socket..
    Aug 2015
    Thanks mga sir sa inputs nyo, tama nga hinala ko na related sa headlight wiring yun problem may pinalitan lang na part (Inattach ko un pic, makikita nyo un parang bungi which is nasunog na part) Salamat ulit mga sir sa input, mas mabilis na troubleshoot un problem.
Burning Smell in Steering Wheel
