Results 1 to 5 of 5
    May 2009
    bouncing ang fuel gage needle....hindi gaya ng iba na fluctuating very slowly. eto bouncing kapag tumatakbo ang sasakyan. steady na kapag tumigil sasakyan.
    fuel tank unit/sender-float assembly? fuel gage? may anti-slosh module ba kung tawagin ang mga isuzu pickups 99 model?
    Feb 2009
    Fuel sloshing. Either change fuel tank or pack the fuel tank with steel wool making room for the sending unit float . You can use 1/2 chicken wire fabric to keep them away from restricting float movement
    May 2009
    inangkupo! sandamakmak na steel wool iyan...hehe.
    fuel tank replacement? mas malabo po iyan.
    subukan ko muna palitan ng sending unit kahit mumurahin lang muna, pag may time.
    Feb 2009
    First thing on my mind was urethane foam but I don't know the quality if it does not dissolve in gasoline
    May 2009
    ano masasabi nyo mga chief tungkol dito:
    nadisconnect na battery (negative terminal) pero nakaregister pa rin yung fuel level sa gage (dash)....may sariling power supply ba ang fuel gage? ngayon ko lang naencounter tong ganito.
    kapag finufull tank ko e nasa F mark naman at mukhang tama naman ang nireregister nyang level base sa km reading sa trip meter.
Bouncing fuel gage needle (when vehicle is moving)
