Results 1 to 8 of 8
    Apr 2009
    Even if my handbrake is down ir not in use the handbrake light indicator in dashboard will appear from time to time. What could be the problem? Corolla 1997 1.6 gli here
    Feb 2009
    Quote Originally Posted by bail View Post
    Check master cylinder brake fluid level
    Fluid level, brake pads.
    The switch that detects if the handbrake is up (on) or down (off) is now defective... or worn out
    It is located near the base of the handbrake.
    Have it checked.
    _/_/_/
    30.3K _/_/_/_/_/_/_/_/_/_/
    Mar 2004
    Brake fluid level ...
    Apr 2010
    On one of my diesel vehicles, there is a hose coming out from the alternator - pag tinanggal mo yun or may butas, iilaw ang hand brake indicator, baka meron din sa inyo
    Pinaka obvious na unang gawin is check the fluid level. Then go from there.
    Jun 2012
    That should be a worn-out park brake switch.
Handbrake light indicator appearing
