Results 1 to 10 of 10
July 2nd, 2011 05:18 AM #1
Hello everyone..
my dad just installed a new Autopage alarm from Autoline and now he's keep asking me kung pano e disable yung alarm..
kasi pag napapacarwash siya or something ay, the alarm keeps on engaging..
naiinis siya na he needs to keep on pressing the unlock button if the alarm went on, shempre pag nagpa carwash ka ay gagalaw talaga yung oto..
please advise TIA
- Apr 2010
- 46
July 2nd, 2011 06:49 PM #2remove the the fuse of the alarm..nandun po siya sa ilalim ng manibela ...in line fuse po yon kung tawagin...or remove the socket of the sensor module...nandun din po siya....magkakatabi lang po sila...
July 2nd, 2011 07:22 PM #3
disarm it. why would you activate the alarm during car wash. have the sensitivity set to minimum as well
July 2nd, 2011 08:31 PM #4
it depends ata sa model ng autopage kung paano disarm alarm. nasa manual yung mga paano, pero kung walang manual, try to search the model online on how to disarm it.
July 11th, 2011 02:44 AM #5
Just put the alarm into "valet" mode. Look for the alarm switch and LED, put your engine into ACC. Press the alarm switch until the LED remains on (not blinking).
- May 2006
- 913
July 14th, 2011 08:25 PM #6you can disarm it by pressing the bottom with the picture of the boot compartment opening.. by pressing it twice right after you unlock the car using the alarm.. you will know that you have disarm the alarm because the LED will remain on. without blinking..
read the manual.. it will should you how to do it..
November 20th, 2011 10:53 PM #7
Need some help guys
My problem is that I can't seem to permanently set my alarm to be just set to "Automatic Rearm OFF". My default alarming is 1 chirp and my de-alarming chirp is always twice instead of the should be 1 chirp as well that's why it keeps on re alarming itself every after 30seconds even though my locks are still unlocked.
I tried to do the Alarm Feature "1" programming but my disarm would not still be corrected. Still got 2 chirps on it after it.
Thanks for the help sirs!
November 20th, 2011 11:20 PM #8
It's an automatic feature on the autopage alarm that after you disarmed it, without any actions on you vehicle. It will auto-arm itself after about 30 seconds unless you leave 1 of your doors opnened. Called passive alarming. Problem is, can't seem to deactivate it even after reading the manual's instruction
November 21st, 2011 05:01 AM #9
try this: press disarm, wait for it to complete, press trunk release twice, not too rapidly i hope
:btw: please mention the model code of your alarm when you ask for assistance. each brand of alarm has a line of models sometimes with different operating instructions
December 29th, 2016 02:33 PM #10
Reviving this thread.
Anyone knows a permanent solution to disable autoarm/ passive arming and autolocking of autopage alarms?
Problem with autoarm is you keep on pressing rhe disarm button while with autolocking, you can be locked out if you step out of the car with the engine running. Manual is of no help since itll say programmable but no clear instructions to disable it permanently
Tesla Philippines
