Results 1 to 10 of 19
- Jul 2011
- 77
March 27th, 2019 11:47 AM #1Hello guys, just wanted to get your inputs if electrical or mechanical ung problem ko.
Last week, na-discharge ung battery ng car ko. I was able to jump start it with our other vehicle pero ngayon ung mga ilaw ng ABS and Handbreak is always on when I start the car. The handbreak works pero pag binitawan mo di nawawala ung on light nya.
Also while the engine is active, the readings from my voltmeter is around 12v lng. Tumataas lang to 13v when I step on the gas, pag idle naman, minsan nagdidip to 10-11v na lang before setting in the 12v range.
Battery is Motolite - around 18 months na ung age. Na discharge na rin sya once or twice before. Does this mean na malapit na mamatay ung battery kaya it messes up with the other electricals sa car? I read that a weak battery can make your other warning lights light up.
Many thanks for your input.
March 27th, 2019 12:00 PM #2
sinagot ka na sa tpc ..
TipidPC.com - Car Mechanics (Got car problems? We're here)
redwing0001 Send Message View User Items on 27 Mar 19 * 10:45 AM #
alternator yan.... dapat mga 13.8 to 14.4V yan at idle with no other electricals on.... at hindi dapat bumababa ng 10-11V pag bagsak ng rpm...
kung may battery charger ka, tanggalin mo yung isang polo ng baterya at kargahan mo... check mo kung aabot ng 13.8V ang full charge AT tanggalin mo yung charger pag full na... tapos check voltage after a day habang nakatanggal yung polo... dapat di bababa 12.2-12.6V yan.. pag bumabagsak ng 10-11V ang battery voltage, pedeng baterya na yan.
- Jul 2011
- 77
March 27th, 2019 12:29 PM #3
- Apr 2008
- 6,235
March 27th, 2019 04:38 PM #4Under warranty pa ba ang Motolite mo? Try to go to the shop where you bought the battery from and have them check it out. See if the lights are still on after replacing the battery. If not, perhaps it is your alternator which is acting up.
March 27th, 2019 05:37 PM #5
naka-on din abs light ng suv ko since naayos at napaandar due to discharge battery and busted fuse.
- Jul 2011
- 77
April 2nd, 2019 01:42 PM #6I'll try to bring the car to Motolite when my work sched clears up. Currently using our other vehicle as my daily driver in the meantime. I already received the Suoer charger from Lazada yesterday and it doesn't say if I have to disconnect the battery terminals from the battery itself during charger.
- 53,883
April 3rd, 2019 10:03 AM #7
April 3rd, 2019 11:07 AM #8
- Feb 2019
- 58
May 15th, 2019 06:16 AM #9See if the lights are still on after replacing the battery. If not, perhaps it is your alternator which is acting up.
- May 2011
- 481
May 15th, 2019 06:24 AM #10
Newer cars don't like the battery disconnected. The KAM (keep alive memory) goes blank may have partial or total amnesia and must be relearned or reprogrammed. If it should be necessary, use a memory saver plugged into the DLC3 or obd2 port supplying battery voltage to terminal 16 and ground to terminal 5.
Tesla Philippines
