Results 1 to 10 of 20
- Jun 2008
- 24
December 4th, 2009 07:21 PM #1Our compact sedan is currently on display at our main showroom at EDSA Balintawak QC.
ENGINE
Type: 4G13S1
No. of cylinders, arrangement: 4 in line, transversely mounted at front Valves mechanisim 16 valves SOHC
Bore×Stroke (mm) : 71×82
Displacement (cc): 1299
Maximum power (kw / rpm): 69/6000
Maximum torque (Nm / rpm): 114/4500
Compression ratio 10:1
Emission control: electronic controlled injection system
Fuel injection system: Electronic multipoint injection
Fuel type: Petrol
TRANSMISSION
Gearbox, no. of speeds: 5MT
Gear ratio: Ⅰ:3.583/Ⅱ:2.043/Ⅲ:1.412/Ⅳ:1.105/Ⅴ:0.881/R:3.615
Final drive ratio: 4.25
STEERING SYSTEM
Rack type: Rack-and-pinion with hydraulic assistant unit
BRAKE
Front: Discs
Rear: Drums
ABS+EBD ★
SUSPENSION
Front: Independent Macpherson strut with spiral spring
Rear: Two-link independent suspension with spiral spring
DIMENSION
Overall length (mm) 4155
Overall width (mm) 1650
Overall height (mm) 1445
Wheel base (mm) 2400
Front tread (mm) 1425
Rear tread (mm) 1415
Front overhang (mm) 825
Rear overhang (mm) 930
CAPACITIES
Curb weight (kg): 1100
Maximum loading capacity(include passengers) (kg): 375
Maximum design total mass (kg): 1475
Fuel tank capacity (litres): 45
Passengers: 5
Boot capacity (litres): 458
PERFORMANCE
Minimum ground clearance(Full load) (mm) 110
Minimum turning radius (m) 5
Angle of approach (º) 16
Angle of departure (º) 17
Top speed (km/h) 170
Acceleration: 0-100 km/h (Sec.) 16.4
WHEEL Tyre 175/65 R14 82H
PRICE: Php 568,000.00
PROMO DISCOUNT: Less Php 40,000.00
- Jun 2008
- 24
December 4th, 2009 08:22 PM #3
Wow buti't nilabas nayan dito ng JAC..
4G13 ng Mitsubishi ang engine nya..Ok to gawing taxi o fleet car!
BANNED BANNED BANNED
- Nov 2008
- 1,383
December 5th, 2009 12:03 AM #4
Wow, a Tach inside a Speedo, that FUNKY. I hope the driver doesn't get duling.
- Jun 2008
- 24
December 7th, 2009 01:01 PM #7
December 7th, 2009 01:54 PM #8
hehehe OK ah 4G13 na EFI? Tinalo pa Lancer.
Anyway sir, parang hindi pantay ang pintura sa second pic? sadya ba yun? parang weird hehehe
anyway, mas interesting yung Starex GRX look-alike. magkano yun sir?
- Jun 2008
- 24
December 7th, 2009 06:46 PM #10
Tesla Philippines
