Results 1 to 9 of 9
    Jun 2016
    Hi,
    Sino po sino may idea sa Normal Oil Pressure range? Kasi I observed last April nasa 60% then last Month I observed na bumaba sya sa 38%, then last week first PMS ni Trax, then kanina when I checked sa Menu icon indicator nasa 29% sya... Normal po ba sya? Thanks.
    Konti lng owners ng trax. Anyways is this on the instrument gauge cluster? Normally oil pressures arent that important. Fuel pressure is important. Maybe you're seeing boost pressure from the turbo?
    Have a look at the owners manual. It details everything you see on the instrument cluster.
    Jun 2016
    Yah! on the instrument gauge cluster. It is the pitcher like icon.. Attachment 32931
    Ah pitcher. Yeah its oil pressure. It shouldnt light up. It means you are probably low in oil. Or you need an oil change.
    Then percentage means oil life. 0% means time to get an oil change.
    Chevrolet has an oil life calculator. Depends on how you drive and how long the oil has been inside.
    Jun 2016
    Thanks a lot po sa reply.. Kaka Change oil ko lang kasi nung last week, Di naman sya nag light.. bale bago kasi ako mag drive chini check ko muna mga menu.. So napansin ko lang kasi na parang bumaba oil pressure nya..
    Jun 2016
    Now I get it hahah. There's an oil life resetting menu pala. Di lang nila (casa) na reset after i change oil. At di din nila alam daw dahil first time nilang nakapag change oil ng trax
    Chevrolet oil life monitor pala aka OLM
    Na brain fart ako when i said oil life calcu... toinks.
    Similar meaning but chevy uses "olm"
    Jun 2008
    Monitor lang yan ng svc hrs next oil change. Dapat I reset every oil change.
    Sent from my Lenovo A7000-a using Tsikot Forums mobile app
    Jun 2016
    hihihi... OLM pala now I know.. may natutunan ako sa iyo. Thanks
Normal Oil Pressure Range
