Page 6 of 7 FirstFirst ... 234567 LastLast
Results 51 to 60 of 70
    Sep 2021
    #51
    I know what you mean, and I agree with you na at least, mabuti obvious na biglang kumalas na lang under "light" use. Ibig sabihin palpak talaga yung design/gawa.
    What I'm saying is, mahirap makipagsapalaran sa mga kotseng dubious ang quality. Gagastos ka na nga lang, yung pangit/alanganin pa bibilhin. Pareho naman halos presyo sa ibang kotse. If sa highway nangyari yung incident na yan, malaking sakuna sigurado.
    #52
    Quote Originally Posted by Miles_on View Post
    You mean to say hindi to freak accident or nagkataong minalas lang. Isispin mo what would have happened if nasa expressway nangyari yan at highway speeds
    Mabuti pa nga nga sana kung Mighty Bond. Baka yung China made na imitiation glue na binebenta lang sa bangketa at Mr. DIY
    Malaysia nga pala, sakto Mr. DIY bahaha
    #53
    Cherry Malaysia
    the "weld" looks so... flimsy!
    nothing like what a computerized welding machine would do.
    sabi nga ng isa, parang estudyante ang gumawa. so superficial!
    Jul 2014
    #54
    Ay may welding pala..dko napansin.
    (I had welding lessons in high school)
    #55
    Quote Originally Posted by Mask Rider Blac View Post
    actually,
    when i first saw the images,
    it thought it was soldered and not welded.
    Jan 2009
    #56
    It was spot-welded, looks like it.The presence of surface rust along the supposedly solid interface seems to suggest that there was an air gap between them and has been like that for at least a while prior to the incident.
    Serpentza featured it...
    #57
    i can see it now,
    worker 1 : "hey, bud, it's almost lunchtime. i'll just spot-weld this, then have lunch, then properly weld it all round afterward."
    worker 2 : "ok, bud."
    worker 1 never came back to finish the job.
    then worker 3 came along : "now, who left this here? it should have been brought to the pile of 'finished welds' over there. i'll bring it there myself."
    #58
    A robot's work is only as good as what its human programmer wants it to do.
    Feb 2014
    #59
    hindi spot welded yan. spot welding is used on join thin body panels together. it looks like MIG
    i do MIG (w/ shielding gas) at home here's a fairly recent weld that i did. there are a lot of variables that could affect weld quality: wire speed, voltage, surface prep, poor grounding, worn out tips, etc
    #60
    Weld preparation is poor. The WPS should have clearly specified what's to be done.
    Given that this is a critical car component, a bevel should have been applied first to achieve a full penetration weld, or a fillet weld should have been completed around the entire joint.
Chery returns to PH
