Results 1 to 5 of 5
July 21st, 2011 07:50 PM #1
Tsikoteers,
just wanted to ask lang..i just had a cobra alarm installed on my unit...just like the AVT,pag open yung door at off ang engine, automatic na nag-o-on yung hazard lights...pag nman naka-on ang engine at naopen any door, same pag nakapatay makina, automatic naghahazard sya but at the same time, the alarm is chirping kasabay sa blink ng lights....ganun ba talaga latest ng Cobra??one time kasi na nasa mall parking ako, may isang car na ganun din while the driver is loading his groceries, naka-on ang engine and the hazard lights are blinking together with a continuous chirping sound...natigil lang sya pag isinara mo na ang doors...thanks in advance..
- Sep 2011
- 16
September 19th, 2011 02:07 PM #3
yung hazard lights ko di sya gumagana pag ino-on or off ko yung cobra alarm ko or kapag nakabukas any door ng sasakyan...unlike dati nung kaka-install lang ng alarm, ok pa sya...i called up the installer and sabi nya possible sa fuse lang since gumagana nman ang hazard lights ko..may nagkaproblem na po ba ng ganito sa inyo?than ks po..
- Sep 2011
- 16
- Sep 2011
- 16
September 22nd, 2011 06:15 PM #5Paste ko narin dito para sa ibang maka expirience.
[QOUTE]
Oo. Pero nalaman ko yung fuse eh kung may naririnig ka paring tiktik... tunog ng relay yun... hanapin mo... sundan mo kung saan nilagay... ako nakita ko sa ilalim ng stearing wheel... malapit sa clutch pedal.
May makikita ka dung fuse box... sa baba nya... dun ko narinig yung tik tik ng relay... may katabi syang fuse na kulay red na malaki. 7.5 amps sya...
Expiirence ko, naka 3 akong fuse kasi laging pumuputok... so i decided to increase the amps based sa fuse box ng accent which is 10amps... so ngayon 10amps na sya at wala na akong na encounter na problem.
[/QOUTE]
Tesla Philippines
