Results 1 to 8 of 8
- Nov 2009
- 3
April 20th, 2010 01:08 PM #1Hi guys! I bought a secondhand car and it had a venom car alarm installed. Unfortunately, it doesn't come with the manual. I was hoping there are a few kind souls out there na puwede po mag-send ng copy nung venom car alarm manual.
Also, i'm experiencing a problem right now. The doors wont lock if i activate the alarm through the remote. Mag-lock siya pero mag-unlock ulit. Kahit manual central lock nung pinto through the door lock itself ayaw na rin. Ano po kaya yung puwede ko i-check? Has anyone had the same experience? Any help will be greatly appreciated. Thanks!
- Apr 2010
- 30
April 20th, 2010 01:40 PM #2
- Nov 2009
- 3
April 20th, 2010 02:57 PM #3Thanks! I haven't checked the fuse though. Wala kasi akong available na pliers plus yung fuse remover wala din sa fuse box. I'll do that muna and if it still doesnt do it, I'll bring it na. Manual nalang kulang. Teehee. Thanks ulit!
May 6th, 2010 10:59 AM #4
my venom alarm now has problems like yours. sometimes it will lock, sometimes it wont
i read something here about resetting the alarm system. im going to look for it.
May 6th, 2010 12:20 PM #5
+1 check nalang fuse muna.
yung problema sa akin, one remote is not working anymore after a change of remote battery, kahit gumagana naman yung LED. parang nabago ata frequency niya. yung isa, minsan gumagana, minsan hindi.Last edited by rion; May 6th, 2010 at 12:27 PM.
May 8th, 2010 07:04 AM #6
kita ko na.
press Lock and Unlock buttons simultaneously, til a beep - Valet mode.
press both again to go back, Beep. (Normal Mode)
it's a sort of "Reset" for the Alarm.
- Nov 2009
- 3
June 25th, 2010 10:24 AM #7I got mine solved but the problem was with the actuator. However, as i was trying to switch to valet mode. it wont work with the arm and disarm pressed together. doesn't even beep. the voice reminder to close the door and activate alarm can be quite annoying.
- Oct 2015
- 1
October 22nd, 2015 12:55 PM #8My venom alarm when I buy it comes w/ 2remote, the slim one and the fat one. After 2 months of my alarm installation, nagkaproblema yung fat one n remote, I need to press a button so many times before it work, or I need to press and hold it like 3-4 mins before mag lock or open ang door. Yung slim remote walang problema not until natapakan ko xa at one of the fuse inside ay nasira, and now pinagtatyagaan ko yung fat remote habang tumatagal nakaka inis na kc nagmamalfunction nga..
Tesla Philippines
