Results 1 to 10 of 385
    Jan 2009
    +/- 1 PSI is an acceptable tolerance.
    I always pump my own tires using a shop compressor. Then I use an Accutire digital tire gauge (it's voted to provide very accurate results).
    My TPMS is reading around 0.5 PSI higher than the Accutire.... it's a little hard to tell. The TPMS does not show decimal values.
    May 2010
    I removed all of the lock nuts on the external sensors today after encountering difficulty removing one of them. It was made of brass and got corroded, probably because our dog loves to pee on the tires hehe. Took me some time to get it off because I did not want to damage the tire valve.
    Jan 2009
    Quote Originally Posted by keto View Post
    Next time, apply a little silicone spray around the valve stem prior to screwing on the lock-nut and sensor.
    May 2010
    I actually used silicone grease. The lock nut also got stuck on the external sensor housing and not the valve stem.
    May pag-xenomorph yata tong aso namin, masyado acidic ang wiwi haha
TPMS (Tire Pressure Monitoring System)
