Results 31 to 40 of 385
September 6th, 2015 02:50 PM #31
Try checking other China brand. Mas mahal ang Steelmate by almost double sa ibang brand na parehas ang features niya. Nauna lang and steelmate sa business na alarm and sensor kaya mas kilala sila at mas mahal.
- Jun 2015
- 37
November 21st, 2015 03:55 PM #32Sir any recommendations who sells tpms and installs them? Makati / Pasay area
- May 2015
- 40
November 24th, 2015 10:19 PM #33
Tsikot Member Rank 3
- Nov 2002
- 1,770
November 25th, 2015 12:38 PM #34questions on the external sensors:
1. do you have to remove them entirely when adding air to your tire?
2. do you just twist it in when installing? does this mean that the "pito" will be continuously pressed while it is installed? di kaya masira ang pito core in the long run?
TIA
- May 2015
- 40
November 27th, 2015 10:36 PM #351. yes. but since namomonitor ko na ang pressure realtime di pa ako nagpahangin since i installed it 3 months ago.
2. threaded sya and just like installing a valve cap may lock nut lang sya para di madaling manakaw. yes pressed ang pito while installed and i am not sure kung masisira nga sya spring lang naman yong stressed. but who cares if masira ang pito it just cost P50
- Jun 2015
- 22
January 16th, 2016 05:20 PM #36Hi Guys,
For those looking for an aftermarket TPMS, we have new stocks for Steelmate models including DIY and Professionally installed TPMS.
Models available:
TP-74 DIY TPMS w/ Cig plug display - 7,490
TP-71I Professional TPMS w/ Cig plug display - 7,990
TP-10I Professional TPMS w/ LCD Display - 7,990
TP-05 Professional TPMS for Head Unit installation (good for vehicles with head unit/ DVD installed) - 8,490
For more details you can check
Safecar Electronics PH
Automotive Parts & Accessories – Safecar Electronics
Thanks!
January 30th, 2016 04:30 PM #37
- Feb 2016
- 5
February 8th, 2016 02:49 PM #38Hi,
Has anyone tried connecting the TP-05 to Growl Audio's head unit? I'm thinking of getting the TP-05 but I'm not sure how it will work with my HU. Also, how will it actually work? I read you need to press the TPMS button, but would you need to navigate through the HU menu to get to the readings? Or does it automatically trigger the application to launch just like the backup camera when the car is put on reverse?
Thanks!
April 15th, 2016 02:09 PM #39
ok SAna nga iyong mga aftermarket tpms sensors na powered by our vehicle's lighter plug units.
ang problema ko lang dito kasi baka ngatngatin ng aso namin at medyo crowded na iyong lighter adaptor ko w/ the dashcam and the thermometer/voltmeter plugged into it
BANNED BANNED BANNED
- Jan 2015
- 4,580
April 15th, 2016 08:41 PM #40
