Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Hi mga Sir, saan ko po ba pwede paayos yung isang remote nung alarm/ keyless entry ko.
    Nung una pumapalya lang sya, sinusumpong, until hindi na talaga sya gumana. akala namin battery ang problema.
    Nagpunta kami sa concorde kung san sya binili, binuksan nung tagaduon tapos napagana nya, hindi naman pala battery ang deperensya.pero ilang gamit lang ganun nanaman...
    Ano po kaya problema??
    baka yung contact ng battery ang may problem. linisin yung contact.
    subukan ko po sir...maraming salamat
    Quote Originally Posted by pdx View Post
    in my experience...
    the battery isn't terribly expensive.
    just replace it, po.
    and clean the contacts in the process.
    i equate "dirty contact" to weak batteries. (how can the contact get dirty in there?)
    Baka yun contact kailgan mo I bend palabas, na flat na siguro
    in my experience...
    that's what i was wondering... paano madudumihan yun eh sarado yun? and i'm not sure about the battery... kasi bihira naman magamit yun.. yung key na may problema is yung laging nakasabit sa sala. nagagamit lang sya tuwing wala ako at nasa work (im working abroad nga pala - 1 month away then 1 month at home). Yung madalas kong gamit na susi nasa drawer lang sa kwarto pag nasa work ako. nagagamit lang yung isang susi pag pinagddrive ng in-law ko yung mag-ina ko pag may lakad sila. so paano hihina yung battery nya??
    try ko na lang po linisin yung contacts as per your advise. may nabili na din akong battery nung nagpunta kami ng concorde, ikakabit ko na din para sure.
    salamat po mga sirs!!
    my suspicion is, the battery slowly leaks and the chemical acts on the metal contacts. the amounts involved are so small, we do not notice them when we inspect them. but when we wipe them batteries and contacts clean, the electrical connection is restored.
    tama yung tao.. madumi nga ang contact. but it will keep on recurring, until the offending battery is replaced by another one that does not leak at all.
    Thanks Doc, gawin ko po yan pagkauwi ko. marami pong salamat!!
    Mar 2016
    ask lng ung sa GS ng kuya ko! kapag ng lock unlock ka first try ok nmn kapag inulit 2nd 3rd parang nalolowbat ung ibang pinto hindi nagana?kadalasan ung driver's door! saka ung isang sliding door ayaw n tlg! manual nalang...posible problem nun? bago battery...kaya imposible bat. thanks
    Quote Originally Posted by GrandStarexTci View Post
    hindi siguro low bat yan. all the doors' actuators get electricity from the car's battery. if the battery were that weak, you won't even be able to make the starter solenoid click.
    kung low bat naman yung susian, ay lahat nang pinto ang hindi magsasara o mag-bubukas.
    hinala ko... wear and tear ng actuators... or loose connections.
    happy trouble-shooting.
Keyless entry remote control problem
