Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Sep 2013
    Hello,
    I just found out this morning that any key can be use to open the lock of my car's driver's side. I tried using our house door key and it worked. Even tried another key and it also worked. I tried doing the same testing on the passenger side, fortunately, it is not the same as the driver's side. To which shop can I have this fixed? Have anyone experienced the same issue as mine?
    Thanks!
    Apr 2013
    Quote Originally Posted by mark_celiz09 View Post
    Hello,
    Thanks!
    I supposed your car is not remote /keyless entry,so gastado na driver's side door entry,better change to anew set of key lock/ entry
    Sep 2013
    Where can i buy a set? Is the ignition key included in the set?
    Posted via Tsikot Mobile App
    Aug 2012
    3 locks/set ang nakikita ko sa sulit. Solex brand. i think this is for driver side + passenger side + trunk/rear door. actually, kahit yung driver side lang palitan mo eh. but if gusto mo same key yung 3 doors, change mo lahat.
    sa ignition naman, keep it as is and use the old key. hindi naman bibigat ang keychain with 1 extra key.
    if you want, pa-install ka na rin ng alarm with central lock system pare keyless entry na with remote.
    where to buy? Ace, Concorde, Blade, etc. or punta ka Banawe area.
    Sep 2013
    Nakita ko ung solex na brand na nakita mo sa sulit kaso di kakasya sa oto ko ung pre. Maliit kasi ung susian and nakalubog ung susian ng oto. Honda civic 97 ung oto ko pre.
    Oct 2013
    Kung makakahanap ka ng susian na similar sa oem, may mga locksmith na kaya nyang baguhin yung pins sa loob ng new locks mo to fit your old key, kahit isa lang palitan pwede..
    Beep Beep! School Bus! Beep Beep! School Bus!
    Sep 2012
    Pwede solex sa iyo Sir... may kaartehan lang kasi yung design nya na kailangan nakalabas yung brand kaya parang malaki pero for sure meron dyan mag fit sa iyo...
    Mahirap yan ganyan baka matsambahan ka sa parking may nag try buksan auto mo
    Aug 2012
    for sure, may kakasya dyan bro.. example, Solex Model 1300GTX.
    Sep 2013
    Salamat mga sir sa info. Try ko maghanap ng ganun. Salamat!
    Nov 2012
    punta ka ng banawe TS dami dun locksmith palinis mo lang yung susian mo malamang na-stock lang yung pin niya na nakapantay kaya kahit anong susi pwede, ganyan din sa tropa ko dati kahit nga flat screw isaksak mo iikot pa din at bubukas pinto nung binaklas namin konting taktak ng susian ayos na ulit pero after ilang weeks ganon na naman dinala niya daw sa banawe binuksan din tapos binabad ata sa penetrating oil tapos nilagyan ng konting grasa ung outer para di pasukin ng alikabok at tubig ok na mga 1 year na siguro di pa ulit nagloko
Door lock can be opened by any key. Where can I have this fixed?
