Results 1 to 10 of 14
- Jun 2008
- 10
November 1st, 2008 08:52 AM #1I am currently using "cobra alarm system" and I was badly in need for some advice on how to disable the beep sound each time I open the door of my car.
usually, it continuously beeping for around 10 seconds yata.
Medyo anoying na eh... di ko naman makita sa manual kung paano ma disable iyon.
thanks po!
November 1st, 2008 10:04 AM #2
Bagong-kabit lang ba? 10 seconds is too long for an audible disarm indication. Baka nagkamali lang sa installation.
If it's a recent problem, try looking in the manual about how the alarm informs you audibly when there's an error or tampering in the system which a faulty part might be causing.
- Jun 2008
- 10
- Jun 2008
- 10
November 1st, 2008 03:16 PM #4it was just newly installed. di ko naman maibalik sa nag install dahil sa medyo malayo iyong place niya.
maybe it was possible for me to do it alone. if i can have the right advice on how to do it.
November 1st, 2008 05:51 PM #5
- Feb 2009
- 1
February 24th, 2009 02:22 PM #6mga bro, naayos ba yung problem sa cobra alarm? I also have the same problem (beeping when door is open). Really annoying. Really want to disable it. Hope you can help me too.
Thanks!
February 26th, 2009 04:28 PM #7
Hindi naman kaya yung lights on or key left in ignition warning ang tumutunog?
Kasi yung Cobra may feature siya that flashes the parklamps when a door is opened. But if the engine is off, the lights-left-on reminder will beep also.
My solution for that is to wire the alarm to the signal lamps instead of to the parklamps.
- Jun 2008
- 2
March 26th, 2009 10:59 PM #8I also have the same problem. The alarm beeps 10 times when a door is opened. How did you solve it?
- Mar 2009
- 1
March 29th, 2009 12:28 PM #9Guys, if you still have this problem on your Cobra alarm, try this... Disarm the alarm (simply unlock using the remote) then open the door. While door is open, press the lock and silent buttons at the same time. This should solve the problem.
- Nov 2008
- 31
April 25th, 2009 11:23 AM #10help mga sir,
im trying out the cobra-8-128 talking alarm with lcd for a week. questions ko lang for those familiar with this
1) how do i change the "speaking tones" to chirp mode? what combo button functions to use?
2) ano tong valet mode? (sorry for the ignorance)
3) whats this feature na power up close all windows when alarm is activated?
thanks po!
Tesla Philippines
