Page 29 of 34 FirstFirst ... 19252627282930313233 ... LastLast
Results 281 to 290 of 337
    Aug 2011
    #281
    mga sir, san po nabibili yung force alarm? or may binebenta si jameson? thanks!
    Aug 2011
    #282
    mavovoid ba warranty ko sa honda if papainstall ako ng force alarm kay jemson?
    Jul 2011
    #283
    Quote Originally Posted by jazzinmypants View Post
    There are shops in banawe that sells force alarm (the ones where jemson buys his goods). But IMHO, just let him buy and have him install it.
    Yes, it will void your electrical warranty (if you still have). But if you think about it, what on earth will happen to the electricals of your bnew? car
    Aug 2011
    #284
    sino may manual ng force car alarm? pls pm me. thanks
    #285
    kailangan ko din ng manual nito, baka meron kayo mga sir, paki e-mail na lang po. tanunoy*gmail.com TIA.
    Jan 2009
    #286
    mga sirs,
    naexperience nyo ba ito sa force nyo? yung samin kasi biglang nawala yung sound ng alarm. pero gumagana pa naman.
    thanks!
    Jan 2009
    #287
    I'm not sure about the GD (other GD owners can chime in). Nabenta na kasi namin yung GD.
    But on my Patrol, the door ajar warning also doesn't work with the key cylinder in the OFF position. The dome lamps still turn on when set in the DOOR position but the dash lamp doesn't illuminate. And that is the OEM set up even before any work was done on my vehicle.
    Not also sure about the rear doors. But that is how our former Volvo also worked (it had a more expensive Autopage system). The system cannot detect the tailgate as it uses a different wiring harness from the other doors.
    Better to have it checked with Jemson na lang to be sure.
    Better also to ask him if he put in the ignition kill. One sure way to test it is to arm the alarm, open doors manually (siren will sound) then try to start the vehicle. If car doesn't start, you have ignition kill.
    sir,
    ganun nga ata yung sa gd. sir yung ignition kill ba yung nagpalagay kayo ng additional switch na pang bypass if ever nagkaproblem?
    btw, naexperience nyo po ba sa alarm nyo yung ganito, kasi minsan pag arm ko, di pa ko nakakalayo tapos biglang tutunog ng isa parang warning, tapos biglang mag aalarm na. minsan bigla lang nagiging ganito yung alarm.
    Jul 2010
    #288
    Force Alarms users,
    anybody na nasiraan na ng remote? I had mine installed August 1 lang by Jemson so fairly new pa. Last week nung umaga when i arrived sa office okay pa ung remote at na-arm ko pa ung alarm, pagbalik ko sa hapon ayaw na ung remote mag disarm. Hindi naman nabagsak or something yung remote. I'm using the spare already. Covered naman to ng warranty dba? Sabi Jemson 1 year warranty ung unit e. The faulty remote's indicator still lights whenever you press arm or disarm, pero it doesn't trigger the alarm system.
    Sep 2005
    #289
    dala mo ba parati yung spare?? baka grounded lang yan.. send nang send nang signal yung isang remote.. kaya ayaw gumana nung isa..
    Jul 2010
    #290
    bro nung nasiraan ako ng remote hindi ko dala yung spare asa bahay. so i had to do the manual override disarm.
Budget Special: FORCE Vehicle Security System
