Results 81 to 90 of 337
- Oct 2009
- 8
October 19th, 2009 04:06 PM #81i bought the force alarm last saturday from sir jameson. maganda yung alarm based on my needs.
ito napansin ko sa alarm:
- medyo nahihinaan ako sa siren, pero pwede naman palitan yun ng ibang siren.
- di ko ma-configure yung password change setup. sinunod ko naman yung nasa manual na "9x gagawin", pero mukhang ayaw. meron na po ba nakapag-change ng password?
- mukhang nadi-disable yung alarm module pag umaandar na yung kotse, kasi tinry ko i-lock yung kotse while the engine is running, pero ayaw. yung dati kong alarm, pwede yung ganun. useful kasi ito minsan pag madalian lang yung pagbaba (i.e. daan sa cr ng gasoline station) para di na papatayin yung engine. di ko lang sure kung out of scope ito nung force alarm or pwede magawan ng paraaan
*marvinix: meron po syang shock sensor, merong knob na maliit yun. afaik, dapat kinabit yun sa isang matigas na part ng kotse mo (i.e. chassis). most likely nasa area yun sa ilalim ng driver side dashboard
*otep: i like the way you recommend the force alarm, and the electrician you suggested. ok na ok po si sir jameson. many thanks for the recommendation
October 19th, 2009 07:27 PM #82
Installed the Force Alarm kanina lang. The whole thing lasted from I think 10am hanggang 5:30
Not in the negative way, pasaway lang ang auto ko.
The alarm costed me 1700 pesos. Not bad. Masaya na ako. with 300 petot labor. Dinalahan ko ng breakfast si Jameson kasi baka di pa kumakain umagang umaga dinistorbo ko. Overall cost is 6000 kanina. 4000 lang dala ko pera babalik ko bukas yung 2000. Madaling kausap si Jameson highly recommended.
I will post yung mga pinagawa ko sa auto as reference to our fellow tsikoteers.
Force Alarm: 1700 pesos
Installation: 300 pesos
Diode para sa signal light yung light ng alarm: 150 pesos
Stebel Magnum horn: 650 pesos
Installation: 100 pesos
My central lock is not working and so is my power mirrors. Nag submarine kasi ang kotse ko noong bagyong Ondoy, mga kalahating tao pa above the roof ang tubig. At nababad dun for 6 hours. Na asikaso ko lang ang auto after 3 days, dun ko lang na disconnect ang battery.
Repair of the motor locks sa pinto: 300 each door. 5 door ang tsikot ko, sabi ko 1,200 na lang okay naman. Na stock up kasi ang motor ng power lock ko.
Module for the power lock, 650. Yung utak lang ang kinuha, babalikan ko ang galamay bukas.
Repair of the stock up motor sa power mirror: 800 for the pair.
Repair of the naglolokong fog light, nilagyan ng relay and wiring, 500.
Nabitin pera ko eh ibabalik ko na lang bukas.
Overall, happy ako. Tigbak ang kotse ko eh, estimate sa casa is 50k conservative, wala pang parts na papalitan yung comp box lang. 10k pa lang nagagastos ko gumagana na lahat except the EPS. Happy ako nag ka power locks ako, nag ka sensor alarm pa. Happy rin ako gumagana na power mirrors ko at ang fog lights di na nagloloko.
October 20th, 2009 01:33 AM #83
Iba ata yung gumagawa ng EPS pero kakilala din nila. I also recommended his services to my friend who submarined a Nissan Xtrail last Ondoy.
- Oct 2009
- 6
October 20th, 2009 08:24 AM #84Boss OTEP pagamit nadin po ng pangalan mo pagkontak ko kay jameson. Nagloloko na din kasi yung cobra alarm ko and need replacement na. If ever, may iba pa ba na pwedeng ikabit si jameson na alarm aside from Force? TIA!
October 20th, 2009 10:15 AM #85
Bro grifter nag-i-install si Jameson ng kahit anong alarm. Nag tanong nga ako ng viper sa kanya worth 4,500 pero sabi ko as to function ano pinag kaiba, same lang din naman.
Doc Otep - meron dun lumapit sakin yun kasama nila na gumagawa ng ECU box for 15k. Buti yung box ko ayos kahit submerged for a long time. Singil niya sakin for the EPS is 7.5k. Medyo di pa kasi ako nakakapag canvass at baka bumigay din kasi pag hininang niya ulit. Tanong tanong muna ako sa Toyota.
October 20th, 2009 01:20 PM #86
I usually just bring anything electronic to his stall to have it installed. Including lights, emergency equipment, etc.
He's also good with audio systems but if you want a tuned box, siguro bring your own box na lang. hehehe. They do have and can make basic box designs, though.
He can work on everything from a '48 Ford to my dad's R107 SLK.
He's also the only guy I know that can disarm and remove an airbag equipped steering wheel using basic tools.
- Nov 2007
- 412
October 21st, 2009 12:26 AM #87ayaw talagang mag-alarm sakin if nakaopen harap na pinto then I press ARM sa remote. whatcha think guys pwede ba itong i-DIY or balik na lang ako kay jameson? pasay pa kase ako galing eh. anyways, itext ko rin sha tom baka pwedeng ako na lang..
- Oct 2009
- 6
October 21st, 2009 02:30 AM #88
- Oct 2006
- 99
October 22nd, 2009 10:51 PM #89mga sir pwede rin po ba silent arm and disarm force alarm or talagang may chirp sound sya everytime activate and deactivate.. thanks..
October 23rd, 2009 11:27 AM #90
