Results 3,291 to 3,300 of 3510
- Oct 2012
- 4,851
July 5th, 2019 01:15 PM #3291Ohhh... which area yung dangerous part na ma deploy yung airbaigs when installing dash cam wire?
I have mine ecosport and cruze before pero im not aware na meron pala ganyan... now, i will try to install it in terra and cx5(soon) but with the post above i have to be carefull since both of them has curtain airbags ...
July 5th, 2019 01:52 PM #3292
- Mar 2019
- 5
July 5th, 2019 03:17 PM #3293https://i.imgur.com/5BL8qzx.png
I'm particularly concerned about the area in green. I'm not keen on disabling the airbags to do this (sorry) pero ayoko din maharangan ang side airbag sa paglatag ng wire. I'm just not that sure whether running it down the side of the windshield will cause any interference.
- Oct 2012
- 4,851
July 5th, 2019 04:44 PM #3294Parang same kami ni jut...
Ganito yung set up ko previously... pero sa windhsield
Area yung wire instead dun sa part ng passenger window side... naka tago lang dun sa plastic cover...
Tapos sa rear cam ganito, sa baba ko dina.an...
July 5th, 2019 05:05 PM #3295
there is a lot of space inside the A pillar. airbag "modules" are not that big.
Installing Dash Cams on Vehicles with Airbags - BlackboxMyCar - YouTube
- Mar 2019
- 5
July 5th, 2019 05:07 PM #3296Last edited by EricDraven; July 5th, 2019 at 05:08 PM. Reason: error in formatting
- Mar 2014
- 694
July 5th, 2019 05:10 PM #3297Buksan mo lang enough yung A-pillar cover para malusot mo yung cable sa pagitan ng airbag and A-pillar. Bale sa driver side ako nagpadaan ng cable. Yung direction ng insertion ko was sa left side ng A pillar. Yung connector sa cable to dashcam ang nilusot ko then hatak nalang papunta dashcam. I did this sa CR-V with airbags on A-pillar
July 5th, 2019 05:14 PM #3298
Tape the dashcam cable onto the A-Pillar behind the airbag, if car is equipped.
- Mar 2019
- 5
July 5th, 2019 05:25 PM #3299
- Mar 2019
- 5
July 5th, 2019 05:30 PM #3300Diyan ako medyo nangingiming magkalikot eh
most videos sa YouTube ng naglalatag ng wire, isinusuksok lang yung wire along the crevice. Meron naman iba na nagtutungkab ng cover like what you did, pero hindi maganda ang track record ko sa mga pagbukas-bukas ng mga ganyan
nakakatakot makabasag ng clip or whatnot, esp. with a car this new. But thanks for the image, it's a big help. Ano'ng oto ito?
