Page 253 of 351 FirstFirst ... 153203243249250251252253254255256257263303 ... LastLast
Results 2,521 to 2,530 of 3510
    Apr 2010
    #2521
    Quote Originally Posted by ParticleX View Post
    Unboxing a Qube X-Cam A7
    Link to full album: Qube X-Cam A7 - Album on Imgur
    Scanned manual: Qube X-Cam A7 Manual - Album on Imgur
    [I]Disclaimer: I do not have any association with Qube, or the OEM of the camera
    ...snipped
    it's almost a year since I bought it, still works very good. checked their website, di na ata available
    countless times na rin siya tanggal-kabit when parking on unsafe spots. pag nasa bahay lang, I do not bother to remove it
    kinuha ko yung sd card niya and put it into a raspberry pi, ok pa naman pero I like the new one on the dashcam. pareho pa rin binili ko, its a samsung evo 32gb (mp-32d ata)
    recently lang ako kumuha ng rearview mount for it, around 320 sa "zada". 'square' ang mount point nya, similar to the G1W
    gusto ko sana kumuha for the rear naman, and am eyeing the G1W, "pwede na" and meron sa nabanggit na online store at around 1k+ lang, cheap enough I guess. problema lang siguro sa mounting and wiring, ayoko ng suction type on a tinted window. merong flat plastic cover yung 3rd brake light kaso suction lang yung kasamang mount
    Jan 2017
    #2522
    Good day! We're planning to buy a dashcam (either Transcend DP 200 or 220), nagkakaproblema po ba ang batteries (or ang unit) kapag matagal nakababad sa araw? Parating na kasi ang summer at roughly maghapon nakapark sa open carpark ang sasakyan.
    Nov 2007
    #2523
    I have the qube A7 also for nearly a year na rin. Namamatay sya after a while sa 1 sasakyan ko but linipat ko sya sa van at never na sya namamatay na. Excellent ang quality ng videos nya especially at night. Passed by qube at mukhang wala na silang benta ng A7. A12 model na lang meron at 4999php.
    Apr 2010
    #2524
    Quote Originally Posted by JJB View Post
    nangyari na rin sa akin pero i have sorted it out, either:
    - maluwag yung stock cigarette port. nung nilipat ko na sa port splitter, i ensured na tight fit na siya. pwede rin i set ang delay ng auto shutdown, for example nalubak at na dislodge yung saksakan
    - corrupt yung memory card. nung nagtetesting pa ako ng differet cards, pag di siya maka write after several secondsag off siya. put a good card and ok na
    after i have the kinks sorted out, very reliable na siya. basta pag hindi sa bahay naka park, lagi kong tinatanggal
    Oct 2009
    #2525
    Quote Originally Posted by kyuzo07 View Post
    just remove it while it is parked. otherwise get a capacitor type.
    May 2009
    #2526
    so far so good naman yung G1W-C ko since october last year pa lang naman. too early to say. i do hope na tumagal.
    kasi never ko pa tinanggal sa windshield na walang tint tapos 8 hrs a day minimum na nakababad sa open parking lot.
    twice pa lang na nadismount mag-isa dahil siguro sa init. talagang nalaglag sa dashboard.
    Apr 2006
    #2527
    Quote Originally Posted by miked View Post
    what specific memory card are you using? my almost 1 year old g1w-c has been encountering memory error/stop recording lately.
    Oct 2013
    #2528
    Sa mga naka xiaomi yi na more than 1 yr na since nabili, kamusta naman performance ngayon? Thinking of buying this since half the price siya ng transcend DP 220 pero concerned sa long term reliability
    May 2013
    #2529
    For those using the hardwire kit, where do you tap the other wire? Is the ignition same as ACC? An electrician I spoke with, told me that, it should be tap on the lighter port, maari daw masunog yung dash cam pag sa ignition, because higher daw ang amp/current/volt*. Putok na daw dash cam mo, hinde pa blown ang fuse. Atleast pag daw sa cig port, same lang ng current/amp/volt*.
    Inputs would be highly appreciated.
    Thank you.
    * -Not really sure about the right term
    Apr 2010
    #2530
    anyone here tried
    nakamichi ND28
    Nakamichi
    and
    versa sentry
    http://versa.ph/versa-sentry/
Blackbox DVR/Dashcam
