Results 2,521 to 2,530 of 3510
- Apr 2010
- 740
January 14th, 2017 10:11 PM #2521it's almost a year since I bought it, still works very good. checked their website, di na ata available
countless times na rin siya tanggal-kabit when parking on unsafe spots. pag nasa bahay lang, I do not bother to remove it
kinuha ko yung sd card niya and put it into a raspberry pi, ok pa naman pero I like the new one on the dashcam. pareho pa rin binili ko, its a samsung evo 32gb (mp-32d ata)
recently lang ako kumuha ng rearview mount for it, around 320 sa "zada". 'square' ang mount point nya, similar to the G1W
gusto ko sana kumuha for the rear naman, and am eyeing the G1W, "pwede na" and meron sa nabanggit na online store at around 1k+ lang, cheap enough I guess. problema lang siguro sa mounting and wiring, ayoko ng suction type on a tinted window. merong flat plastic cover yung 3rd brake light kaso suction lang yung kasamang mount
- Jan 2017
- 1
January 16th, 2017 12:34 AM #2522Good day! We're planning to buy a dashcam (either Transcend DP 200 or 220), nagkakaproblema po ba ang batteries (or ang unit) kapag matagal nakababad sa araw? Parating na kasi ang summer at roughly maghapon nakapark sa open carpark ang sasakyan.
January 16th, 2017 01:10 AM #2523
I have the qube A7 also for nearly a year na rin. Namamatay sya after a while sa 1 sasakyan ko but linipat ko sya sa van at never na sya namamatay na. Excellent ang quality ng videos nya especially at night. Passed by qube at mukhang wala na silang benta ng A7. A12 model na lang meron at 4999php.
- Apr 2010
- 740
January 16th, 2017 06:13 AM #2524nangyari na rin sa akin pero i have sorted it out, either:
- maluwag yung stock cigarette port. nung nilipat ko na sa port splitter, i ensured na tight fit na siya. pwede rin i set ang delay ng auto shutdown, for example nalubak at na dislodge yung saksakan
- corrupt yung memory card. nung nagtetesting pa ako ng differet cards, pag di siya maka write after several secondsag off siya. put a good card and ok na
after i have the kinks sorted out, very reliable na siya. basta pag hindi sa bahay naka park, lagi kong tinatanggal
- Oct 2009
- 348
January 16th, 2017 03:50 PM #2525
January 17th, 2017 12:43 PM #2526
so far so good naman yung G1W-C ko since october last year pa lang naman. too early to say. i do hope na tumagal.
kasi never ko pa tinanggal sa windshield na walang tint tapos 8 hrs a day minimum na nakababad sa open parking lot.
twice pa lang na nadismount mag-isa dahil siguro sa init. talagang nalaglag sa dashboard.
- Apr 2006
- 40
January 17th, 2017 05:32 PM #2527
- Oct 2013
- 170
January 20th, 2017 11:53 PM #2528Sa mga naka xiaomi yi na more than 1 yr na since nabili, kamusta naman performance ngayon? Thinking of buying this since half the price siya ng transcend DP 220 pero concerned sa long term reliability
- May 2013
- 223
January 23rd, 2017 12:56 PM #2529For those using the hardwire kit, where do you tap the other wire? Is the ignition same as ACC? An electrician I spoke with, told me that, it should be tap on the lighter port, maari daw masunog yung dash cam pag sa ignition, because higher daw ang amp/current/volt*. Putok na daw dash cam mo, hinde pa blown ang fuse. Atleast pag daw sa cig port, same lang ng current/amp/volt*.
Inputs would be highly appreciated.
Thank you.
* -Not really sure about the right term
- Apr 2010
- 118
January 23rd, 2017 01:04 PM #2530anyone here tried
nakamichi ND28
Nakamichi
and
versa sentry
http://versa.ph/versa-sentry/
