Results 1,881 to 1,890 of 3510
June 27th, 2016 04:35 PM #1881
I contacted their head office through their FB page. Out of stock daw and earliest possible delivery is end of July but not sure yet.
Meron din GPS logger bro yung 0805. Mas discrete pa kasi mas maliit.
Between suction and adhesive, mas matibay naman siguro yung adhesive 'no? Hindi ko naman tatanggalin or lilipat sa ibang kotse so ok lang na permanent.
June 27th, 2016 08:07 PM #1882
- Jun 2012
- 4,447
June 27th, 2016 08:09 PM #1883
June 27th, 2016 08:15 PM #1884
I bought my Qube A7 (2 sets) from their Solenad 3, Sta. Rosa branch. Actually it's just a showroom. I went there personally and ordered 1 after the other of the dashcam. Tip: If you chose to power up the A7 dashcam directly from the lighter port, suggest you install a kill switch.
June 27th, 2016 08:23 PM #1885
May workaround dyan kung gusto mo ng suction or wala kang mahanap na adhesive mount. Para hindi mahulog yung unit with the suction cup, using the 3m mounting tape, cut strips of it (about 5mm wide). Careful not to touch the exposed adhesive part of the tape. Stick the strips around the edges of the suction cup, the part of which that will touch the windscreen surface. Confirm the placement by marking the area with masking tape. Kung masaya ka na sa placement, peel off the the 3m tape and carefully mount the suction cup.
- Jun 2012
- 4,447
June 27th, 2016 08:26 PM #1886
June 27th, 2016 08:40 PM #1887
- Jun 2012
- 4,447
June 27th, 2016 08:42 PM #1888
- Jun 2012
- 4,447
June 27th, 2016 08:47 PM #1889
Pag tinanggal kasi yung screw ng mount, ganyan mangyari, meron kayang something universal adhesive mount na magshoot dyan? From action cam, etc..
June 27th, 2016 08:55 PM #1890
In my experience it is stable. I used this method on my wife's garmin gps. She's been always complaining of the suction cup fall out but nung nilagyan ko ng mounting tape tahimik na sya, he he. Imagine mas mabigat ang gps device as against the lighter dashcams. Mas matibay lalo sya kung lahat ng surface ng suction cup is covered with the tape.
