Results 1,871 to 1,880 of 3510
June 27th, 2016 11:00 AM #1872
I'm not an expert on these matters but between Qube Xcam A7 and Mine 0805, i choose the latter. It fits all your requirements. I guess you'll just have to wait a little longer w/ Lazada
June 27th, 2016 12:01 PM #1873
Will try to drop by Qube later, hopefully may available na A7. If it's too big, might wait for the 0805.
June 27th, 2016 12:59 PM #1874
tried that approach with my sj4000. it won't last long. didikit siya tapos pag nabilad sa araw, unti-unting mag-sag until mahulog na. i even replaced the adhesive with 3m heavy duty mounting tape (yung black na ginagamit sa car accessories like rain gutter), di umubra. natatanggal din eventually. maybe it is because of the non-smooth surface of the rearview mirror.
June 27th, 2016 02:31 PM #1875
* jut
does strapping the mount with the rain sensor housing with black zip-ties isn't feasible?
June 27th, 2016 03:02 PM #1876
How did you mount your SJ4000 then?
I'm thinking if hindi kaya sa rain sensor, adhesive nalang sa windshield. More stable than the suction cup I think. Though I plan to put it on the dot matrix part para hindi visible.
Zip ties will not be stable and looks cheap. I want to keep it as clean as possible.
June 27th, 2016 03:13 PM #1877
Walang stock ng Xcam A7! [emoji30]
And then yung mga Mini 0805 na nasa Lazada, all of them are imported, so I don't know if the products are really available, and if I will be able to return/replace the product in case it's defective. The only local supplier of the Mini 0805 doesn't have stock either.
To A7 and 0805 users, hope you can help point me to suppliers with stocks. Thanks!
- Apr 2010
- 740
June 27th, 2016 03:20 PM #1878Marami branches ang Qube, meron 2 within the vicinity of Gilmore. Have you called the branch before going in? Yun ang isa pang gusto ko sa X-Cam, may storefront and warranty claims should be easier.
I believe they accept shipping but haven't tried it, check their website
June 27th, 2016 03:47 PM #1879
may optional GPS logger and speed display yata yung A7. mukhang maganda add on ito.
June 27th, 2016 04:19 PM #1880
