Page 93 of 351 FirstFirst ... 4383899091929394959697103143193 ... LastLast
Results 921 to 930 of 3510
    Aug 2006
    #921
    Quote Originally Posted by keto View Post
    ^^ Thanks for all the feedback regarding nighttime settings.
    No windshield tint so default exposure settings seem to give me the best results. Upping the exposure to even +1/3 gives me problems with glare at night especially with light sources, ie oncoming vehicles headlamps and streetlights. The fact that I also have Phillips Xtremevision bulbs adds to this issue when it reflects on the plate number from the vehicles I'm following. The glare is so bad sometimes that it makes the plate numbers of vehicles in front of me unreadable.
    I've also settled on 720p because I can set capture rate at 60fps. Will try disabling audio, as it is parang almost 1gb per 10 min yung file size.
    I also ordered 5m long usb cables, will try some cable management once it arrives.
    I have similar issue with glare.
    I have 3M Magic Tint which is compensated by Osram Night Breaker.
    Problem is, the glare from vehicles directly in front makes it hard to read the plate numbers. Even with the naked eye, its a problem.
    Aug 2006
    #922
    Click image for larger version.
Name:	ImageUploadedByTsikot Forums1439335315.843823.jpg
    Screen capture of my DP220's night time video
    Para di ko na i upload yung pagkalaki laking video file
    May 2015
    #923
    Quote Originally Posted by npor View Post
    Im using a 64gb adata sd card on my dp220 which I previously used on my phone at wala naman ako naexperience na error. Maybe bad card na yun nagamit mo bro
    thanks for the info. baka nga compatibility issue lang. i used strontium 64GB sdcard na ginagamit ko sa tab at wala namang problem sa tab. i will try to get adata sdcard this time. did you format it just using DP220?
    Nov 2014
    #924
    Replaced my SJ4000 cable with 3m flat USB cable:
    Jul 2003
    #925
    Transcend Introduces DrivePro 520 Car Video Recorder for Dual Lens Recording -Press-About Us-Welcome to the Transcend Info Website
    transcend 520. dual cam na
    http://ph.transcend-info.com/About/press/10937
    Sep 2008
    #926
    was hoping the price to be included so we have an idea
    Jul 2015
    #927
    Im still waiting for the thinkware f750 to go down in price, maybe just convincing myself that i need one. who else here use their phone as a dashcam? And what app do you use? Im Using vidometer and dashcam btw.
    Jul 2012
    #928
    Does your SJ4000 heat up after driving for 1 hour? Does activating the 'screensaver' so that the display will turn off when recording helps?
    #929
    Quote Originally Posted by leodawesome View Post
    I drive for several hours a day, and my SJ4000 doesn't heat up. Yes, I have the LCD turned off when recording. Di ko naman titingnan yun while driving, distraction lang.
    Jan 2013
    #930
    Quote Originally Posted by Servus View Post
    Di na ako nagfomat. Just deleted the data using my computer then diretso saksak na sa dp220
Blackbox DVR/Dashcam
