Results 1 to 7 of 7
- May 2018
- 16
May 8th, 2018 01:36 PM #1hi mga boss. ask ko lang po, bigla kasi nawala yung horn honk ng remote lock ko ng civic 2004 dimension, paano po ba ibalik yung horn honk sa default pangalawang pindot mo ng lock sa remote. lahat gumana gana, remote lock, etc. yung remote lock horn confirmation lng nya ay para naging silent mode...
at ang warning beep like sa seatbelt ko po ay nawala din. pls help... tnx...
May 8th, 2018 02:00 PM #2
It is possible that the "horn" is already busted. If the alarm is directly connected to the car's horn instead of an attachment, then you should consult an electrician to check the fuse, relay, etc.
Otherwise, you may have done something that made it in silent mode. You can try to search for the brand and look for instructions since most probably, you have lost the manual just like me.
- May 2018
- 16
May 8th, 2018 02:28 PM #3tnx for the reply...
the horn is not busted, gumagana po ang horn. yung horn confirmation lng talaga sa remote lock nag silent mode. pati yung seat belt reminder pag tumakbo na at certain distance/speed ay nasilent.. pero sa pag saksak ng susi ay tumutunog ang seat belt reminder...
May 8th, 2018 02:40 PM #4
The next best thing to do, if I were you, is to have a competent electrician check it since the belt reminder is affected. Those guys from Honda Guiguinto doesn't charge that much, I just don't know to other dealers.
Some shops are really good, but you need to spend time looking for one.
- May 2018
- 16
- May 2018
- 16
- Jul 2018
- 4
July 6th, 2018 03:35 AM #7
Tesla Philippines
