Results 101 to 110 of 116
- Feb 2011
- 101
April 11th, 2015 11:19 AM #101
- Jun 2015
- 41
May 29th, 2016 11:16 PM #103
- Jun 2015
- 41
May 29th, 2016 11:43 PM #104Sir yung stock cable ba hindi pwedeng gamitin? I'm planning to buy the Nuvi 57 sana.
May 29th, 2016 11:51 PM #105
Depende sa connectors sir. Most powerbanks have micro USB cables while most (if not all) Garmins have mini USB charging ports. I have both the nuvi 960 an nuvi 2565, pareho silang mini USB. Ewan ko lang sa latest models sir. Kung pasok naman yung connectors ng powerbank mo sir, pwede dapat yan
Sent from my D6503 using Tapatalk
- Jan 2011
- 132
May 30th, 2016 09:59 AM #106You can charge a Garmin with a powerbank using stock cable. However, using the stock cable will make the Garmin go into PC connection mode. It won't do if you're planning on using the Garmin for navigation while connected in this way.
One of the pins in the oem Garmin car charger mini usb connector is wired differently so it doesn't go into pc connection mode. You can search for it with Google. You'll have to modify your usb cable in the same way if you plan on navigating while connected to a powerbank.
May 30th, 2016 01:07 PM #107
- Apr 2010
- 97
May 30th, 2016 02:42 PM #108mga bossing, pwede pa po ba magamit ung nuvi 1300 dito sa pinas? sabi kasi sa garmin dealer sa subic obsolete na daw ung model at di na daw pwede madownloadan ng phil map? sayang naman kasi kung di magamit, galing US po sya. help naman po kung pano magdownload ng map kung pwede pa magamit, salamat.
- Jan 2011
- 132
May 30th, 2016 03:15 PM #109
May 30th, 2016 07:28 PM #110
Pwede pa yan sir. Yung isang nuvi ko is 960 (which seems older than yours), nagana pa naman sya. Depende siguro sa map na tinutukoy nya yun. Marami din naman maps dyan like openstreetmap or roadguide. Need lang maging contributor sa roadguide to gain access to the comprehensive map.
Tesla Philippines
