Results 21 to 30 of 259
April 16th, 2013 08:58 AM #21
tried this before. depende sa battery ng fon mo kung tatagal o hindi ung charge nya.
gamit ko samsung note 2 and OsmAnd GPS app.
ung routing naman depende sa map na nakaload sayo. sa fon ko mabilis naman ung routing and reliable. nung minsan galing ako subic pabalik na ako manila via SCTEX tapos nalagpasan ko ung Dinalupihan exit. My GPS rerouted me through the next exit Floridablanca and reached NLEX.
ang reklamo ko lang talaga eh kalimitan mabagal sya mag-lock sa GPS signal sa umpisa.
April 16th, 2013 10:20 AM #22
^^^ One of the possible inconveniences of using a device not designed for that function....
Your choice.....
18.8K:dance1:
April 16th, 2013 10:54 AM #23
- May 2011
- 114
April 16th, 2013 11:12 AM #24But my Garmin on my iPhone 5 gets a sat lock in under 10seconds once I'm on the road.
Power supply is never a problem as you can always use a USB charger plugged to the 12V source.
Sent from my iPad 4 using Tapatalk
BANNED BANNED BANNED
- Jul 2003
- 2,267
April 16th, 2013 11:51 AM #25When we went to Daet, Cam Norte, I used Papago M8 in my iPhone4s.
My friend who was in the other vehicle brought his Garmin.
To my surprise, he turned off his device when we were in Nagcarlan, Laguna because it kept telling them to make a U-Turn. The device/software was probably not aware of the Nagcarlan-Lukban-Pagbilao route going to Quezon. At one point, they were instructed to make a left turn which happens to be towards a ravine in Camarines Norte (Bitulang Manok).
I'm not saying my iPhone is better but let us not be too dependent on these devices although sometimes I'm guilty on this one. When I travel long distances to unfamiliar places, I try to research first and visualize everything. I use google maps etc to increase awareness of the route I'm taking.
ok pa nga yang 10 meters. Dapat on your part, alerto ka na 200 meters from your destination. Hindi naman instantaneous ang update GPS.
April 16th, 2013 11:52 AM #26
April 16th, 2013 12:03 PM #27
dati kasi nung baguhang driver pa ko at di ko pa masyado kabisado ung mga daanan sa Manila kaya napaisip ako bumili. tapos may opismate ako na naka-GPS na mura lang (around 5K) so napabili ako. para lang ba mas confident gumala at nde nagsasayang ng gas kasi iwas maligaw.
so initially nagagamit ko talaga sya. nung tumagal nde na. nagagamit ko na lang sya pag out-of-town (usually papuntang north ) or pag nagagawi paminsan-minsan sa mga liblib na lugar dito sa Manila.
April 16th, 2013 12:07 PM #28
if you have it then good if you dont phone will do...I don't really thing kailangan pa bumili ng GPS if your car is not equip with one...saan ba dito sa manila ang mahirap puntahan at maliligaw pa?
April 16th, 2013 12:23 PM #29
April 16th, 2013 12:27 PM #30
For Garmin to give them direction your friend has activated a route to your destination, depending on the setting, either, fastest route or shorter route the route plotted on garmin will vary. He should have check the routes before he accepted it. He can edit the route by adding waypoints (via) in between destination. His Garmin shouldn't be any different from Papago because they use the same roadguide map.
Garmin GPS are for serious road tripper, because you can efficiently plan your trips and routes especially if you have mapsource. The GPS will also guide you with the road shape ahead and help you when making decision to overtake safely, You can also upload waypoints with proximity alert warnings, like waypoints for railroad crossings, bridges , known bad roads etc. You can also customize the screen to give you driving info, like, time to destination, distance to destination, estimated arrival time, etc. I also have garmin GPS in my smartphones.but I rarely use this for long trips.
If you are a city dweller, smartphone is ok, if you are a serious or frequent road tripper, a real garmin gps with good map is a must have. .
