Results 1 to 4 of 4
April 7th, 2005 02:38 PM #1
nawala kasi headlights ko last night & i want to know where i could get it fixed na magaling pero d naman masyado pricey...it couldn't be the bulbs kasi nawala lahat pati fog lamps eh.. clearance lights lang natira... it could just be relays or fuses but if i just replace them di ganun pa din, masisira din ulit...
i need someone who could fix the problem para di na ma-ulit. before kasi ayaw lang mag dim, when i switch it to dim naka bright pa din so i'm just on bright all the time... with that pa lang i already know there may be something wrong with the switch or grounded wiring, tapos last night wala na pati bright & even my fog lamps.
pls help! thanks.
April 7th, 2005 02:41 PM #2
sungard,along motortown.
look for mike. tell him you are recommended by vlady.
April 7th, 2005 04:01 PM #4
bro. yung labor hindi. madaling kausap yang si mike. pero hwag ka bibili ng parts dun sa kanila. medyo mahal yung tindahan.
for reference.... sya rin nag setup ng sounds ko. labor is around 500 lang. tapos nagbigay lang ako ng tip na additional 300 because he did a great job.
